Goodman Heat Pump - HVAC - DIY Chatroom Home Improvement Forum
Old 06-05-2011, 03:37 PM   #1
Goodman Heat Pump
I have a CPL T36 1B Goodman heat pump it stopped producing cool air today what might be wrong
4scoops is offline   Reply With Quote
Old 06-05-2011, 06:33 PM   #2
Rewards Points: 6,652
Who knows, since it could be a number of variables. Got colder out, house has no electric, blew a fuse, capacitor went out. Your guess is as good as anyone else's, due to limited info given.
Old 06-05-2011, 08:20 PM   #3
The heat pump is running although the fan stops for an instant after about a minute of running then starts back up just as quick. Would that be the capacitor
Old 06-06-2011, 09:45 AM   #4
Could be. Be careful when checking the capacitor, since it can knock you on your butt if you touch the terminals. You will need a meter that allows for checking resistance, amps, volts. You would be looking for the time of current drain, once it charges.
http://www.repairfaq.org/sam/captest.htm
http://www.angelfire.com/electronic/...ting_caps.html
Goodman GPH1336H21AA heat strip connection jrajra HVAC 2 09-02-2010 04:52 PM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 08:34 PM
New Heat Pump..questions? ddave23 HVAC 4 03-05-2010 05:13 AM
Heat pump vs in floor heat mugen HVAC 5 03-02-2010 08:18 PM
heat pump question David from MD HVAC 3 02-01-2010 08:42 PM
