Goodman Heat Not Engaging With New Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 10-16-2010, 02:17 PM   #1
Goodman heat not engaging with new thermostat
I have a goodman heat pump outdoor unit with a newly installed hunter thermostat. The a/c and blower fan have been functioning fine all summer but this morning when I turned on the heat nothing happened. Here's a list of things I have noted so far:
I don't have the 24volts at the w2 pin on the outside unit when heat is engaged on the thermostat.
Reversing valve functions fine when heat is engaged.
When I jumper the w2 to R (24v) the contacts come together.
The blower fan doesn't come on when I turn the heat on at the thermostat.
Wiring the new thermostat is the same as the old one.
The a/c still functions fine.
Someone please help lol.
autosay97 is offline   Reply With Quote
Old 10-16-2010, 02:44 PM   #2
HVAC / Plumbing
Did you program it for the correct type of heat ?
kenmac is offline   Reply With Quote
Old 10-16-2010, 02:48 PM   #3
Yes, it has two options. 1st option is conventional and 2nd is heat pump. I chose heat pump. Does the thermostat receive some type of feedback before it kicks the blower fan on?
Old 10-16-2010, 02:58 PM   #4
HVAC / Plumbing
it may have a time delay. switch the blower from auto to fan on & see if it comes on. You may have the wiring wrong
Old 10-16-2010, 03:05 PM   #5
The fan does come on when I manually turn it on but the heat pump still does not come on on the outside unit. Are there seperate time delay relays for the air conditioner and the heat pump? If there is then I think I burnt the one up leading to the heat pump. I installed an incorrect thermostat earlier this year which ended up blowing a transformer, I replaced the transformer and that fixed the a/c which was all I tested at the time. If the time delay relay is blown would it prohibit my heat pump/w2 wire on the outiside unit from getting the 24volts it needs to engage? I believe my wiring is correct because everything is functioning flawlessly, I am simply not getting 24volts to the w2 terminal and my blower fan isn't coming on on heat only.
Old 10-16-2010, 06:29 PM   #6
HVAC / Plumbing
probably burn up a fan sequencer. No telling what else .
Old 10-16-2010, 07:32 PM   #7
An old Tradesmen
Rewards Points: 6,116
Post model number of heat pump. Sounds like you have a package unit.
Old 10-16-2010, 07:45 PM   #8
Rewards Points: 392
You basically have 4 wires to the heatpump. The AC/HP compressor/fan (Yellow), The 24v (Red), The Common (Blue), and the Reversing valve (Orange). Don't bother hooking up the W2 wire, it's only used for call for backup heat during a defrost cycle. Just don't hook it up. You probably have a problem like the Yellow wire isn't getting energized..
-Jeff
zootjeff is offline   Reply With Quote
Old 10-16-2010, 07:51 PM   #9
An old Tradesmen
-Jeff
if he has a package unit. He needs the W2 connected.
Old 10-16-2010, 09:02 PM   #10
Rewards Points: 392
I just measured my heatpump and I put the meter on AC volts, put the black wire on Common, Measure:
25V red
25V yellow
0V Orange.
My Goodman Heatpump works great.
I don't have an external fuel kit. Wiring goes straight to my heatpump from my furnace..
-Jeff
Old 10-16-2010, 09:54 PM   #11
An old Tradesmen
25V red
25V yellow
0V Orange.
-Jeff
Do you know what a package unit is?
Old 10-17-2010, 12:45 AM   #12
Rewards Points: 392
Isn't it thing that Andy Sandburg and Justin Timber-lake wrote a song about and got really famous for?
It's a heatpump all in one package with the blower. Not a split system. So basically the house air goes outside the walls to this unit and then back in.
-Jeff
Old 10-17-2010, 05:18 AM   #13
An old Tradesmen
-Jeff
And so if his unit is a package unit. He needs W2 connected if he has more then 10 KW of strip heat. And on some heat kits, if its more then 5 KW of strip heat.
Old 10-17-2010, 09:37 AM   #14
Rewards Points: 392
Yaa,
They never post enough info for people to really help them.
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 01:19 PM
Configure an add-on radiator as stage 1 heat using a Honeywell thermostat hermhart7 HVAC 10 04-28-2010 06:39 PM
Heat pump thermostat emergency switch joe913 HVAC 2 12-10-2009 01:54 PM
programmable thermostat + heat pump Potomac101 HVAC 10 12-03-2008 11:02 AM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 03:11 PM
