Goodman GSU06-3 Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 12-14-2012, 10:56 AM   #1
Goodman GSU06-3 problem
I have a Goodman GSU06-3
That ignites the burners only to stay lit for around 10 secs and then goes out.Blower etc still continues to run and it keeps repeating the cycle but does not trigger an error code. The LED stays o.
Had a Tech come out today and said he cleaned the flame sensor and replaced the terminal connector But still doing the same thing .
He said only thing to do is replace the furnace.
I asked about replacing the flame sensor and was told he's only replaced one in is 30 plus years of HVAC repair.
Everything I've read suggest a faulty / dirty flame sensor.
Should I replace and try to see if it works?
Just does not sound right and think he only wants to sell me a new system.
Help ????
Bubba Jay is offline   Reply With Quote
Old 12-14-2012, 11:24 AM   #2
Items wanted: Time
Rewards Points: 150
Get new tech, he should be able to measure the signal the flame sensor is sending. From there you can determime what the problem is
NiNe O is offline   Reply With Quote
Old 12-14-2012, 11:49 AM   #3
NiNeO
Thank You. Figured he would have measured it for resistance etc. But apparently he just pulled it out and cleaned it.
Old 12-14-2012, 11:57 AM   #4
A flame sensor is just a steel rod with a ceramic insulator. If the ceramic isn't cracked or carbon traced there's nothing to fail on them. Corroded grounds or faulty control boards will do the same.
Old 12-14-2012, 12:17 PM   #5
Going to check grounds and connectors .The house had been vacant for 2 years and I'm thinking corrosion on the terminals. I hope .
But wouldn't it through a fault code if not getting a reading from the Flame sensor?
BTW Thank You guys for helping.
Old 12-14-2012, 02:02 PM   #6
Items wanted: Time
Rewards Points: 150
Ground problem is a likely culprit, make sure the ground is good all the way to the earth.
Old 12-14-2012, 02:50 PM   #7
Roofmaster
Rewards Points: 2,210
Another one???
I have never seen any forum wherein the so called professionals that people call in to look at their HVAC system the answer to almost every problem is to install a new HVAC system. Most of the techs that answer in this forum say to call a licensed Technician, and it seems that most of them tell the Owner that they need a new system.
I guess at the going rate for service techs in the field of HVAC, which I frankly don't know about, the point of diminishing returns is achieved very quickly.
Does anybody know what a trained service tech makes, or a good place to go to school for this trade?
Old 12-14-2012, 02:57 PM   #8
JJboy's Avatar
Around $90000 but you have to offer a lot new system.
Sent from my iPhone using DIY Forum
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 12-14-2012, 03:10 PM   #9
An old Tradesmen
Rewards Points: 7,794
LOL, school is only the basics. Doesn't teach you half of what you need to know to be good.
Old 12-14-2012, 03:29 PM   #10
Roofmaster
Hvac
I agree, like all schools, what you learn there is just the basics. You learn the real stuff in the Bar. 90K is definitely better than a poke in the eye with a sharp stick though.
Old 12-16-2012, 06:05 AM   #11
Items wanted: Time
Rewards Points: 150
Do you have any idea of how much customer crap you have to break and short and catch fire and freeze to become a good HVAC tech. More for some but in my case plenty.
goodman gmpn100 venter problem lucydisguised HVAC 8 02-17-2011 06:37 PM
Septic problem or vent problem? wilsonstark Plumbing 9 01-17-2011 06:35 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Sub is swapping Amana for Goodman Dragon HVAC 22 02-04-2007 07:54 AM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
