Goodman GMV95 Won't Light - HVAC - DIY Chatroom Home Improvement Forum
Old 10-09-2010, 09:30 PM   #1
We just installed a Goodman GMV95 Two Stage furnace. As soon as turned on the electricity the first the it fired up right away and ran solid for an hour. A few hours later I realized the furnace was no longer on. We watched the light and it appears to be flashing continuously (or once, depending on how you read the manual) We have checked the grounds, look good, replaced the thermostat, cleaned the flame sensor with an emery board, scraped out the brass orifices with a paperclip, turned power on and off countless times and cannot figure this out. Any suggestions? We're going to call the gas company as well to have them come back out and look at it.
DandelionKy is offline   Reply With Quote
Old 10-10-2010, 08:37 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,286
Lets start in the beginning. Do you have 24 volts AC from W to C on the circuit board when it is calling for heat. May be using W1 if you used a 2 stage stat.
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 10:40 AM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 08:19 PM
Furnace won't light (Goodman GMP100-3) MattJ HVAC 8 10-03-2008 09:11 AM
