Goodman GMV95 Issue - HVAC - DIY Chatroom Home Improvement Forum
Old 10-03-2009, 07:02 PM   #1
Home Air Direct's Avatar
Goodman GMV95 issue
I have been contacted by a homeowner asking for advice about a 1 year old Goodman GMV95 that is doing the following:
1.The unit cycles through start-up and the igniter heats up, without ignition.
2.The unit will fairly quickly try to start again.
3.The LED diagnostic code is not flashing.
Any idea what the causes can be? The unit was working fine at the end of the last heating season (it's first season).
I will be helping them find a competent servicing contractor in there area.
Settle down! If you were that important, the city would give you lights and a siren for your car
Home Air Direct is offline   Reply With Quote
Old 10-03-2009, 07:30 PM   #2
as seen on tv
Rewards Points: 150
do they have gas,is the valve opening?, pressure switch, tstat calling?, Drains, loose connections etc
qbert is offline   Reply With Quote
Old 10-03-2009, 08:52 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 2,260
If the igniter is weak or has the wrong resistance it may take too long to glow red and be the wrong temp and color which can interrupt the ignition timing. After 4-5 trials for ignition it will flash a lockout code and probably start the cycle after a 1 hr timeout period. If the gas valve is not being energized same scenario. Is their gas turned on to the house? Had a call once where goofs turned the gas off as a prank.
Nordyne condenser goodman A-coil wtroger HVAC 10 09-16-2009 03:52 AM
Central AC Issue: Goodman CK30-1B jsabe HVAC 3 05-26-2009 07:27 PM
HELP - with my breaker box. Interesting issue. LordX Electrical 75 02-23-2009 03:14 PM
Goodman & Roll out switch issue? wsquared HVAC 1 11-10-2007 11:12 PM
Sub is swapping Amana for Goodman Dragon HVAC 22 02-04-2007 07:54 AM
