Goodman GMT090-3 Won't Stay Ignited - HVAC - DIY Chatroom Home Improvement Forum
Old 02-09-2010, 07:32 PM   #1
Goodman GMT090-3 won't stay ignited
The house is cold. Turning the heat off then on and also flipping the breaker gets the fan to turn on but burners won't stay on. Took off the two panels, indicator light is on (no blinks, so no issues per the troubleshooting sticker). Once I put the lower panel back on (pushing on the safety switch) the blower turned on, the unit ignited. All four burners burn hot for about 20 seconds then the burners go off. The house is 59 and I've got the therm set at 69. Kids teeth chattering.
Hope one of you samaritans can help because the van just broke down too. I need a cheap fix. On the other hand, if I need a pro, then I need a pro. Just don't want to spend it if Iit's an easy fix that a reasonably handy guy should be able to handle.
Also- are Goodman furnaces reliable?
Schuptz is offline   Reply With Quote
Old 02-09-2010, 07:37 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,856
Clean the flame sensor with fine emory paper or clean steel wool, sits in front of one of the burners and should look like this:
Old 02-09-2010, 07:52 PM   #3
hvaclover is offline   Reply With Quote
Old 02-09-2010, 07:58 PM   #4
Hvac Pro
yuri's Avatar
The Amana version ain't bad.
Old 02-09-2010, 09:44 PM   #5
Thumbs up
It Worked!!
Thanks so much Yuri! I know, it's early in the game but it's been cranking out hot delicious air for 15 minutes. I read that advice in other posts but your photo and directions made it brain dead simple. THANKS!!! I would love to buy you a beer or two in appreciation.
Old 02-10-2010, 04:02 AM   #6
You see that Yuri? You made it so easy Stevie Wonder could fix it!
U 'Da Man!
Goodman GMP Furnace won't stay lit. JoelT HVAC 10 12-16-2012 11:24 AM
Goodman air handler adjustment Xander08 HVAC 2 12-24-2009 02:32 PM
Goodman gmp075-4 flame won't stay on n2fishin69 HVAC 13 01-29-2009 01:33 PM
Goodman Furnace GMNT100-4b Won't stay on freeslporer HVAC 3 10-30-2008 06:42 PM
Sub is swapping Amana for Goodman Dragon HVAC 22 02-04-2007 07:54 AM
