Goodman GMT Blower Runs Intermittently - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-03-2014, 05:29 PM   #16
An old Tradesmen
Rewards Points: 8,154
Or the capacitor is weak.
Old 08-03-2014, 05:54 PM   #17
Any good way to troubleshoot one from the other? I suppose i could just throw a capacitor at it first, but it would be kinda cool to actually know ahead.
laramsey is offline   Reply With Quote
Old 08-03-2014, 05:56 PM   #18
An old Tradesmen
A multimeter that can read uF.
Old 08-04-2014, 10:11 PM   #19
Hey beenthere - OK, you make a good point. Should have figured that out on my own. Anyway I was able to find a meter with a cap. check, and it is out of tolerance, but not by much. 20 mfd, +/- 6%. Measures 17mfd, spec would be 18.8. I'm going to replace it, & might change the blower motor as well, just to save shipping & hopefully call it done. I guess the blower price will determine that - some are quite expensive, I see.
The cap. has a thin film of oil on the top surface only - clean on the sides & terminals, no accumulation - just a film. Is this a leaky capacitor, or something else, left from manufacturing maybe? Other comments?
I must not be living right - AC in my car quit today.
Old 08-05-2014, 04:16 AM   #20
An old Tradesmen
Sounds like the start of a leaking cap.
Hope your car's A/C is something easy to fix.
Old 08-16-2014, 02:58 PM   #21
OK, so it took a while to get back around to this. I replaced the capacitor (with a new one), no difference. After running only twice for 10 or so seconds, the side of the motor about half way down was pretty hot. So what what do you guys think - is there anything else that could possibly be at fault here, besides the motor? (1/2HP, 1130RPM, 8.8A)
I considered just buying one, but I found it a little difficult to cross reference one.
Thanks everyone
Old 08-16-2014, 03:33 PM   #22
Rewards Points: 3,256
Definitely the motor. It shouldn't be getting hot that quick.
zappa is offline   Reply With Quote
Old 08-16-2014, 05:27 PM   #23
Thought so - and good - because changing the motor is my third pitch and I can't stand to strike out. :-(
So besides specs, which numbers on the motor will matter when I go to order one Monday? In looking online, I can't see how people are cross-referencing these things - few specs, and little or no part numbers are posted.
Old 08-16-2014, 07:08 PM   #24
Well, I don't think there is anything left to replace besides the motor. I have a lot of small motor experience but not on HVAC systems so there might be something quirky that I don't know about. Voltage, HP, RPM, thermally protected, can be made to rotate in the correct direction, fit mechanically, and shaft size/mounting is all I can think of.
Edit: Capacitor value would be nice so you don't have to buy another one.
Old 08-16-2014, 09:05 PM   #25
Well, I don't think there is anything left to replace besides the motor. I have a lot of small motor experience but not on HVAC systems so there might be something quirky that I don't know about. Voltage, HP, RPM, thermally protected, can be made to rotate in the correct direction, fit mechanically, and shaft size is all I can think of.
Agreed - specs should do the job - it would be a lot easier if they were posted. Ironic that in an online, self-service world, they are inviting real, actual, verbal phone calls...
Old 08-16-2014, 10:26 PM   #26
HVAC seems to be one of the last holdouts for DIY. I couldn't even buy a contactor for my heat pump at a local supply house. Had to use a friends account.
Old 09-01-2014, 09:35 AM   #27
So I finally swapped out the blower motor and all is well. Thanks everyone for helping!
The Following User Says Thank You to laramsey For This Useful Post:
zappa (09-01-2014)
Tags
blower , goodman , intermittent
Goodman Gas Furnace blower will not stop cyp555 HVAC 3 11-12-2012 08:37 PM
Heil 5000 Blower Motor Runs Continuously Blowing Cold Air boisechick3770 HVAC 2 11-12-2012 12:08 PM
York furnace - blower motor works intermittently on medium speed jeremyp969 HVAC 4 04-18-2012 12:37 PM
Main Blower Runs All The Time Needmotools HVAC 3 10-28-2011 06:18 PM
Goodman Heat Pump - Blower Motor FireFighter254 HVAC 9 03-05-2010 06:18 AM
