Goodman GMS80453ana INOP - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 07-30-2010, 04:41 PM   #31
Rewards Points: 20
Originally Posted by beenthere View Post
Coils shorting out to itself.
It's been replace, so i am on the next phase of fixing the no cold air coming out. Have any good ideas for the no cool air out of the unit. The unit outside seems to be running fine now.
diynoobee is offline   Reply With Quote
Old 07-30-2010, 04:51 PM   #32
An old Tradesmen
Rewards Points: 8,142
Is the large copper line cold?
Have you checked the indoor blower motor to see if its getting electric?
Old 07-30-2010, 05:20 PM   #33
Rewards Points: 20
How do I tell the difference from the fan and the blower motor?
The copper line is room temp.
Old 07-30-2010, 05:26 PM   #34
An old Tradesmen
If the copper line is room temp when the outdoor unit is running. Then its not working right.
Could be a bad capacitor. Could be the contactor is miswired.
For the indoor unit. Trace the wires back from the blower motor.
Old 07-30-2010, 05:39 PM   #35
While the other unit is still working it'd be good if you measured all the winding/coil resistances and currents. Measuring winding/coil impedances is a little more complicated.
Old 07-30-2010, 06:02 PM   #36
Rewards Points: 20
Ok.. here are the inside unit diagrams
http://www.goodmanmfg.com/Portals/0/pdf/SS/SS-GMS8.pdf
My Meter has a cap checker how do I check the cap?
What do you mean trace back to the Blower motor?
Oh... Looked at the diagram... I guess you mean the cap that is attached to the inside unit, correct3?
Old 07-30-2010, 06:10 PM   #37
Rewards Points: 20
Measuring the impedance should be measuring the 3ea (T1,2 and3) set of the windings and where the T1,2 and 3 share a common point right. What the purpose?
Old 07-30-2010, 06:16 PM   #38
An old Tradesmen
Physically, see where the blower motor wires connect. And then check to see if you have voltage there, when the board calls for the blower to run.
Don't know what meter you have. But generally. You disconnect the cap. And then set your meter to its cap setting. And put your probes on the cap's terminals, and read the mF
Old 07-30-2010, 06:27 PM   #39
Rewards Points: 20
So with the unit running I should have voltage across the cap?
By the way... I can at least tolerate being upstairs now. The attic went from 102deg to 91deg!
Old 07-30-2010, 06:36 PM   #40
An old Tradesmen
Don't have the unit running or voltage going to the cap, and use your meter with it set to mf's.
You'll wipe out your meter.
You can check the voltage with it connected and the unit operating. But, you won't know if its the correct voltage.
The Following User Says Thank You to beenthere For This Useful Post:
diynoobee (07-31-2010)
Old 07-30-2010, 06:41 PM   #41
Rewards Points: 20
Those of you that are reading these post... don't worry I have a healthy fear of being shocked. I do know something about electricity and electronics. I know enough to discharge the caps and have power off.
Old 07-30-2010, 08:01 PM   #42
Getting pass/fail specifications from the good unit that you can use to check the failed unit.
Old 07-31-2010, 08:42 AM   #43
Rewards Points: 20
I guess it took sometime to get going, but It was cool enough to fall asleep upstairs it got so cold I had to turn it off! Thanks for all of the help saved me a bundle and gave me more confidence as a DIYer!!!!!!
Goodman air handler adjustment Xander08 HVAC 2 12-24-2009 02:32 PM
Nordyne condenser goodman A-coil wtroger HVAC 10 09-16-2009 03:52 AM
Evaporator coil for Goodman A/C leschuler HVAC 2 09-25-2008 12:43 PM
goodman furnace nhicks HVAC 3 02-09-2008 06:25 PM
Sub is swapping Amana for Goodman Dragon HVAC 22 02-04-2007 07:54 AM
