Goodman GMS8 Serie, Does Not Work - HVAC - DIY Chatroom Home Improvement Forum
Old 11-06-2010, 09:22 PM   #1
Goodman GMS8 serie, does not work
All parts tested and working good, polarity ok, ignitor 66.9 Ohms, no power on ignitor after ID fan start, then led stay flashing.
Abrahamcas is offline   Reply With Quote
Old 11-07-2010, 05:43 AM   #2
An old Tradesmen
Rewards Points: 6,592
If all parts are working good. Then the HSI must have power.
Since you said it doesn't, some part is not working. Good chance its the board. But you might want to make sure the board has a good ground before you replace it, and have the same problem.
Electrical work in Branford, CT - Can I do it? ControlTech Electrical 11 01-11-2009 01:45 PM
goodman gas furnace won't work consistently 2cold HVAC 1 11-30-2008 11:28 PM
duct work framing kama Carpentry 4 11-15-2008 01:40 PM
is this bad tiling work? garrick Flooring 17 09-27-2006 01:30 AM
