Goodman GMP100-3 Rev B - HVAC - DIY Chatroom Home Improvement Forum
Old 06-10-2008, 08:08 PM   #1
my furnace/AC fan comes on intermittently even when the system is turned off. When the system is on, it will run normaly, (heat or AC) then when the desired temp is reached and the system shuts off, the fan will momentarily stop, then kick back on again and run. Naturally the condition never occurs when experts are present.
Thanks in advance for any ideas.
genegreco is offline   Reply With Quote
Old 06-11-2008, 09:42 PM   #2
Rewards Points: 150
short
likely a short in the contol wire r to g some where and it would help to know if the system was zoned and i will assume the fan on your t stat is in the auto position i know but i go on allot of calls where the cust didnt realize thats what that does
geo fan is offline   Reply With Quote
Old 06-12-2008, 12:33 AM   #3
evaporator coil
I am replacing a 5 ton American Standard evaporator coil. My hvac man suggests Amana over American Standard. Any thoughts on this
laurettem985 is offline   Reply With Quote
Old 06-12-2008, 06:18 PM   #4
Rewards Points: 150
yeah
i use amana as my b brand and wont evvvver instal an a.s. best bang for buck high end cust goes for 23seer maytag or of course man up and go with the GEO-THERMAL
Old 06-12-2008, 07:54 PM   #5
not sure what you mean by "zoned", fan is in auto position.
Old 06-14-2008, 05:31 PM   #6
Rewards Points: 150
zone
when you have multiple thermostats controlling 1 system it requires an additional circuit board which can sometimes give problems
Old 06-16-2008, 04:12 PM   #7
zone
oh no, nothing like that. just a straight up system, 1 thermostat.
thanks for your responses.
Evaporator coil for Goodman A/C leschuler HVAC 2 09-25-2008 12:43 PM
Goodman Furnace does not kick in wctoro HVAC 2 02-20-2008 01:47 PM
goodman furnace nhicks HVAC 3 02-09-2008 06:25 PM
Replacing an 20 year old gas forced air with a 95% 2 stage goodman, goodman 40" tall, englewood1 HVAC 12 09-25-2007 11:37 PM
Sub is swapping Amana for Goodman Dragon HVAC 22 02-04-2007 07:54 AM
