Goodman GMP100-3 Humidifier Issue - HVAC - DIY Chatroom Home Improvement Forum
Old 11-20-2010, 07:32 PM   #1
Exclamation
I have an issue with my humidifier not working correctly. When the heat kicks on, and the furnace kicks into blower mode, the humidifier wheel does not spin I think due to a faulty motor that is mounted on the outside of the humidifier. Because all the humidifier box does is just get really warm with the hot air passing through instead of humidifing the air as the furnace is on. What would be the easiest thing to do, just but a whole new aftermarket humidifier and install it or replace the motor that spins the spindle(wheel) ??? I would like advice on what to do and where online or local hardware stores might have the parts mentioned. Thanks for your help.
olds2000 is offline   Reply With Quote
Old 11-20-2010, 11:18 PM   #2
Replace it with a new one. The big box hardware stores have them pretty cheap.
Tags
gmp100-3 , goodman
Goodman Furnace Burner issue hansim4 HVAC 5 10-08-2009 08:26 PM
Goodman GMV95 issue Home Air Direct HVAC 2 10-03-2009 09:52 PM
Central AC Issue: Goodman CK30-1B jsabe HVAC 3 05-26-2009 08:27 PM
Goodman & Roll out switch issue? wsquared HVAC 1 11-11-2007 12:12 AM
HVAC humidifier issue rfjm58 HVAC 4 04-12-2007 07:46 PM
