Goodman GMP100-3 Gas Furnace Won't Stay Lit - HVAC - DIY Chatroom Home Improvement Forum
Old 11-23-2012, 06:45 PM   #1
Goodman GMP100-3 Gas Furnace won't stay lit
Exhaust blower fan comes on. HSI glows. Gas burners light, but then go out after about 10 seconds.
Have checked 'pressure sensor' by disconnecting connections from sensor & connecting them directly to each other. Same issues as above.
Have cleaned the 'flame sensor' rod & adjacent burner housing.
Also cleaned connections at sensor & circuit board, as well as checking connectors 'clamping'/friction.
With voltmeter set to ACVolts 200, the reading between main 'Neutral' connection on circuit board & 'Ground' (screw on furnace housing) is 1.2.
Reading between 'flame sensor' & 'ground' is 0.2.
I appreciate any assistance.
Thanks.
ldggray is offline   Reply With Quote
Old 11-23-2012, 07:15 PM   #2
An old Tradesmen
Rewards Points: 6,112
GMPs are known for either cracking the heat exchanger, or popping their crimp rings. Check yours,may be time for a new furnace.
Quote for new furnace. Reasonable? dengle HVAC 16 03-04-2012 08:01 AM
Goodman furnace wont light and it is getting cold Rio_Grande HVAC 8 02-13-2012 08:01 AM
Goodman furnace blowing lukewarm air mangust13 HVAC 12 02-19-2009 08:38 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
