Goodman Gmp075 4 Won't Light - HVAC - DIY Chatroom Home Improvement Forum
Old 02-05-2009, 06:05 PM   #1
Tile and Stone
Goodman gmp075 4 won't light
I'm new and need some help. I have a goodman furnace gmp075 4 and it won't light. The igniter heats up then shuts off. Over and over. I cleaned the flame sensor as recommended. Also the led is not flashing, it is on steady. Just no gas being released by the valve assy. Any suggestions?
Steve72 is offline   Reply With Quote
Old 02-05-2009, 06:50 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 180
Do you have an electrical meter and know how to use it? You can check for 24 volts A/C at the valve when the igniter is glowing. Usually has a 30 second warmup period and then energized the gas valve. If not then the board is probably bad. Had lots of trouble with them. The LED should be flashing a flame failure code so I suspect it is the board. Make sure the metal mount that the board is on is securely fastened and that there is continuity from that metal to ground.
Old 02-05-2009, 07:11 PM   #3
Tile and Stone
I will have to get one, I do know how to use one thanks for the reply
Old 02-05-2009, 08:19 PM   #4
Check the manual reset spill switches around the burner box. One may have tripped. The little button between the wires resets the switch. If one is tripped you will want to have that heat exchanger checked. Should be 3 or 4 switches.
SKIP4661 is offline   Reply With Quote
Old 02-05-2009, 09:29 PM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 180
In my experience ALL safeties have to prove B4 the igniter glows. Not my favorite unit.
Old 02-05-2009, 10:24 PM   #6
Correct Yuri.
This is a problem with the control board. The ignitor doesn't stay on long enough to ignite the burners. As soon as the gas valve opens, the ignitor shuts off. Still not enough to ignite.
chard is offline   Reply With Quote
Old 02-06-2009, 06:27 AM   #7
G71
Pro
Agreed, have changed several of those boards this year.
G71 is offline   Reply With Quote
Old 02-06-2009, 05:38 PM   #8
hvaclover is offline   Reply With Quote
Schematic for Goodman Mod. GMP075 AlBen53 HVAC 8 01-29-2009 01:25 PM
Goodman furnace won't light anotherday HVAC 3 10-29-2008 07:03 PM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 08:19 PM
Furnace won't light (Goodman GMP100-3) MattJ HVAC 8 10-03-2008 09:11 AM
