Goodman GMNT FAN - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-11-2012, 04:38 PM   #16
What kind of oil should be used?
BuzzardsBayGUY is offline   Reply With Quote
Old 01-11-2012, 04:41 PM   #17
I'm Your Huckleberry
Rewards Points: 2,270
Try 3 in 1, the household oil. Or some 5w-30 motor oil.
Thanks.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
BuzzardsBayGUY (01-11-2012)
Old 01-18-2012, 12:56 PM   #18
Where is this plug located on the inducer motor? Does it require major disassembly? I was able to oil up the fan shaft and bearing located in the front about five days ago and the motor has yet to make any noise. But if there is a plug to add oil I would like to get that done as well. Thanks
Goodman GMNT 80-4 problem onsetcharlie HVAC 11 01-10-2012 01:11 PM
Goodman GMNT 080-4 inducer problem RiccH HVAC 18 03-26-2011 04:47 AM
Problem: Goodman GMNT to Hunter 44155C Thermostat shipupride HVAC 5 10-11-2009 05:36 PM
Nordyne condenser goodman A-coil wtroger HVAC 10 09-16-2009 04:52 AM
Sub is swapping Amana for Goodman Dragon HVAC 22 02-04-2007 08:54 AM
