Goodman GDS Help - HVAC - DIY Chatroom Home Improvement Forum
Old 11-01-2011, 12:57 AM   #1
Rewards Points: 484
Goodman GDS help
I have a goodman GDS (counterflow) furnace that I will be taking to Reno to replace and old Rheem at my uncles house.
Unlike all of the upflow and horizontal furnaces I have installed over the years, this furnace does not have the vent connector on the outside of the furnace, it has the connector halfway down inside the cabinet.
I dont see anywhere in the manual where it says I cant use a single wall vent pipe inside the unit but it seems like single wall pipe would make things get too hot, circuit board, pressure switch etc. The current furnace is single wall pipe and I planned on using new single wall pipe for the install.
Can someone please give me some insight on this? Thanks.
sammy37 is offline   Reply With Quote
Old 11-01-2011, 09:38 AM   #2
Rewards Points: 484
Anyone?
Old 11-01-2011, 06:50 PM   #3
Rewards Points: 484
Going to go ahead and convert all the single wall to B vent. Trying to find B vent and the proper connectors in this city is a joke. I'll probably have better luck getting what I need in Reno when I get there.
Some of the supply houses here suggested using flexible B vent but I'm not so sure I'm sold on using flexible vent material.
Goodman air handler adjustment Xander08 HVAC 2 12-24-2009 03:32 PM
goodman 3ton dhop11 HVAC 2 11-14-2009 01:02 PM
Nordyne condenser goodman A-coil wtroger HVAC 10 09-16-2009 04:52 AM
Evaporator coil for Goodman A/C leschuler HVAC 2 09-25-2008 01:43 PM
Sub is swapping Amana for Goodman Dragon HVAC 22 02-04-2007 08:54 AM
