Goodman GCVC95 24v Wiring Adapter - HVAC - DIY Chatroom Home Improvement Forum
Old 12-22-2010, 07:30 PM   #1
Rewards Points: 392
Goodman GCVC95 24v wiring adapter
Hi, I need help figuring out how to connect to the Goodman control board.
Please see the attached picture.
1. I need to connect to standard 18 gauge wire but it looks like I need a socket adapter to go to screw driver quick connects. Anyone know the part number/s for these?
2. What are the red stops on the top green housing for?
Thanks,
Jeff
zootjeff is offline   Reply With Quote
Old 12-22-2010, 07:43 PM   #2
Rewards Points: 392
I'm guessing I need something like this:
http://search.digikey.com/scripts/dk...name=ED1742-ND
Old 12-22-2010, 08:55 PM   #3
hvaclover is offline   Reply With Quote
Old 12-23-2010, 01:11 AM   #4
Rewards Points: 392
Originally Posted by hvaclover View Post
Translation?
Old 12-23-2010, 03:46 AM   #5
You need a very small flat head or Phillips screw driver. You can use a watch makers toolkit
[IMG]file:///C:/DOCUME%7E1/John/LOCALS%7E1/Temp/moz-screenshot-1.png[/IMG]
Old 12-23-2010, 10:08 AM   #6
Rewards Points: 392
No the issue is that the furnace didn't come with any adapter to get to the small flat head screwdriver connection points. All it has is the housing shown in the picture. I need to buy some kind of adapter..
Old 12-23-2010, 10:56 AM   #7
HVAC / Plumbing
I have never seen a board come like that the 1 you have. Where did you get the board ?
kenmac is offline   Reply With Quote
Old 12-23-2010, 11:05 AM   #8
Rewards Points: 392
It came on a brand new Goodman 70,000 BTU 95% Efficiency, Two Stage Burner, Variable Speed Blower, Downflow/Horizontal Application Goodman Gas Furnace GCVC950714CX
I'm guessing I should get the http://search.digikey.com/scripts/Dk...me=277-1071-ND
11 position terminal block, but it seems odd that Goodman would rely on field techs to supply these kinds of parts..
Old 12-23-2010, 11:07 AM   #9
HVAC / Plumbing
where did you purchase the unit. I can't recall having to install this adapter on any furnace that we've installed
Old 12-23-2010, 11:08 AM   #10
Rewards Points: 392
We got it from ACwholesalers.com. Its a variable speed downflow... Manual is dated 8/2010.
I just called them and they said they will send me an adapter ASAP and that it should have been provided with the unit. Their customer service is really good so far!
-Jeff
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 08:53 AM
Looking for a HVAC control wiring diagram for Goodman billy carroll HVAC 1 11-14-2010 06:29 AM
Wiring duct fan to Goodman unit GDNTX HVAC 3 11-13-2010 11:12 AM
Goodman Heat Pump 2 Thermostat Wiring RanLoot Electrical 1 05-09-2010 08:20 AM
Sub is swapping Amana for Goodman Dragon HVAC 22 02-04-2007 08:54 AM
