Goodman Gas Question - HVAC - DIY Chatroom Home Improvement Forum
Old 09-29-2011, 02:56 PM   #1
Goodman gas question
I have a new goodman up flow. 2stage variable furnace. Can I just hook up the two thermostat wires off of my existing battery powered programable thermostat to the furnace and to which connectors. Thanks.
Bluenoser60 is offline   Reply With Quote
Old 09-29-2011, 06:54 PM   #2
Rewards Points: 484
Depends on which model you have, some of the two stage Goodmans dont actually use a two stage stat. Which model do you have? What does your manual say?
If it doesnt require an actual two stage stat, then you will hook your wires to the R and W terminals on the furnace and adjust the dip switches accordingly for timing between first and second stage.
sammy37 is offline   Reply With Quote
Old 09-29-2011, 07:31 PM   #3
Its a GMVC95
Old 09-30-2011, 09:32 AM   #4
Rewards Points: 484
You need a two stage stat.
You will need at least four wires between your furnace and thermostat.
R
G
W1
W2
Old 09-30-2011, 02:52 PM   #5
Ok so if I just have the two wires hooked up to r and w1 the furnace will act as a 1 stage?? until i get the proper thermostat.
Old 09-30-2011, 07:50 PM   #6
An old Tradesmen
Rewards Points: 7,318
Get the communicating thermostat that is made or that furnace.
For temp use, just 2 wires are ok.
Old 10-01-2011, 10:38 AM   #7
Rewards Points: 484
I was doing some research on that unit last night and like Beenthere says, the communicating stat would be best.
For now, the manual says to use R and W2 and set the dip switch for high stage.
Old 10-02-2011, 09:40 AM   #8
Thanks for help!! This is a great site.
What I have done is set up the thermostat (2 wire) to R and W1
Also turned dipswitch on S1 (thermostat) to off.
The furnace starts up fine but will wait until a cool day to see it go through a full heating cycle.
Also I plan on picking up a 2 stage stat and installing it when I get a chance
Question on hooking up the compressor on a Goodman brokenhammer HVAC 2 07-25-2009 11:59 AM
Trane XV90 cfm question lyonkster HVAC 36 04-29-2009 02:28 AM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 04:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Goodman ck36-18 question bub HVAC 3 08-15-2008 05:08 PM
