Goodman Gas Pack Outside Fan Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 10-04-2010, 08:08 AM   #1
Hi-I am new to this site and am totally clueless about HVAC issues-however
I would love to avoid a large repair bill if possible.Anyway,this past summer the ac completely quit on my gas pack,which is about 7 years old.Nothing but air blows in.We just used window units for the rest of summer,and planned to have it repaired in fall.So I tried the heat today and it works fine-it is just that the outside fan is not working.It makes a humming sound intermittently like it is trying to turn,but it won't.I tried to turn it by hand to get it to start-it spins freely but will not work.I would like to know if it is safe to run the unit without the outside fan working until we can get it repaired.
Thanks in advance!
tmbenner2004 is offline   Reply With Quote
Old 10-04-2010, 10:28 AM   #2
HVAC / Plumbing
Thanks in advance!
If your talking about the blower motor ( that blows heat into the house) Don't use the unit until this is repaired. If your talking about the vent motor . The unit shouldn't even come on . If it's either motor donot use until repaired
kenmac is offline   Reply With Quote
$1440+ labor only repair on 3 yr. old Goodman unit!?! JMK HVAC 23 05-06-2012 10:45 AM
Weed problem, bug problem, or both? hayzen Landscaping & Lawn Care 1 08-25-2009 06:33 PM
Goodman Gas furnace, A/C will not run new install RCApp HVAC 5 08-04-2009 09:00 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
