Goodman Gas Heat Not Blowing - HVAC - DIY Chatroom Home Improvement Forum
Old 11-09-2012, 11:08 AM   #1
goodman gas Heat not blowing
just need a reseyI have a Goodman Gas heater on my HVAC system Model gmh80904bnca
last night the temp dropped to 54 so I realized the heater wasnt going.
I went to my thermostat and the temp inside read 61 but it was set to heat to 68
I switched the heat to on instead of cool <duh> and I heard the gas click and what i thought was a woosh of the gas bars lighting but the fan never turned on to blow it through the vents after a second or two it did the same thing but no blow on the thrid or forth try it stopped.
Now i can Manually turn the fan on with my thermostat and it will blow cold air because the furnace will not try to ignite
the ac works great and blows so what do i do?
I also noticed a oil residue on the top of the furnace and a little inside but i cant see any cause of the leak.
Help I have cold kids here..Someone suggested a glow ignitor could that be it?
I have tried flipping the breaker off for a while and then back on with no luck was told it may just need a reset
grifter77 is offline   Reply With Quote
Old 11-09-2012, 02:59 PM   #2
iI took the glow ignitor to my hvac part supply house and they said it wasnt registering
the correct oems . But they didn't think it was the issue
here said it was for the pilot lighting the bars and if I am hearing the bars ignite it might be some relay or something else any ideas
Old 11-09-2012, 03:52 PM   #3
Rewards Points: 582
turn thermostat to heat set temp above room temp ..then turn fan on..see if it works to warm house....ben sr
Old 11-09-2012, 06:56 PM   #4
did and same result.
also its not the pilot lighting i am hearing but the exhaust i think
Old 11-09-2012, 10:20 PM   #5
as seen on tv
Rewards Points: 150
If the exhaust mtr is running and nothing else is happening the pressure switch is not making. Make sure flue pipe is unrestricted
qbert is offline   Reply With Quote
Old 11-09-2012, 10:31 PM   #6
Rewards Points: 616
look inside the thing....whats happening ....listening is what we do when music is playing...lol....
carmon is offline   Reply With Quote
Old 11-10-2012, 02:10 AM   #7
how
Rewards Points: 1,102
Turn off the power to the furnace for a few minutes and then turn it back on again with the thermostat calling for heat. Watch & listen if the inducer motor starts up, if the igniter glows and if the burners ignite. Let us know what happens?
This furnace also probably has a led light that flashes a diagnostic sequence that will indicate what the fault is. Usually visable through a viewing port on the furnace door. Record that led sequence and then check inside the furnace for the legend that will explain what it means.
how is offline   Reply With Quote
Old 11-10-2012, 12:50 PM   #8
the igniter glowed red but no flame and iI could not find a led
Old 11-10-2012, 09:56 PM   #9
didn't see a restriction in the vent. As i said the Glow would get red but not ignite the furnace. I thought the exhaust was the pilot light lightning the burners. but I guess I was wrong.
still no blowing of the fan when its light. The supply store said that the glow wasn't producing the correct oems. but he part is almost 70.00 i hate to buy one if its not it
dyson77 is offline   Reply With Quote
Old 11-14-2012, 09:04 AM   #10
Anybody have any ideas. I would hate to spend 75 on a part that May not be it.
Also can anyone recommend a good website site that I can find it cheaper
Old 11-14-2012, 09:09 AM   #11
Also where is the led indicator located. Maybe I'm missing it
Old 11-14-2012, 11:59 AM   #12
Ok did some footwork and found the led
It's solid red. No blinking. But from what I read that means either the board is bad or no signal from thermostat
But it can't be the thermostat because the ac works and the fan.
So what's my next step
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 05:28 PM
Goodman Electric Heat Continously Running jrice41159 HVAC 3 11-27-2011 07:56 PM
the heat in not blowing forcefully thru the vent,very little heat gwendolyn HVAC 2 10-19-2011 09:43 PM
Goodman Heat Pump 4scoops HVAC 3 06-06-2011 10:45 AM
Goodman central air and heat blowing fuses DannyR HVAC 13 05-29-2011 07:21 PM
