Goodman Gas To H/p To All Fuel Board Installation - HVAC - DIY Chatroom Home Improvement Forum
Old 10-23-2015, 04:55 PM   #1
Rewards Points: 14
goodman gas to h/p to all fuel board installation
how do I install outdoor senser to hvac ststem. diagrams shows sensor to tstat but all fuel board shows wiring sensor to the board. which one do I follow. I have a Honeywell wifi vision pro 8000 stat, goodman 96% gas furnace, and goodman 2.5ton h/p
jhillegeer is offline   Reply With Quote
Old 10-23-2015, 05:17 PM   #2
Rewards Points: 3,848
Have no idea on the Goodman board. I just use a visionpro 8000 tstat and make things easy
roughneck is online now   Reply With Quote
Old 10-23-2015, 05:36 PM   #3
Rewards Points: 14
then how do i differentiate gas heat from h/p heat
Old 10-23-2015, 05:38 PM   #4
Rewards Points: 14
i have stat connected to weather station as required , honeywell said to connect outdoor sensor also. i did this and the "gas" cycle does not work.
Old 10-23-2015, 05:49 PM   #5
Rewards Points: 46
The gas will be on "aux" heat. Make sure the pro8000 is setup as gas backup and setup the lockout temps. The tstat requires the sensor in this configuration. Most hp also have some function like this, but require the conversion board for fuel heat.
M/n s?
Cheers!
supers05 is offline   Reply With Quote
The Following User Says Thank You to supers05 For This Useful Post:
jhillegeer (10-23-2015)
Old 10-23-2015, 06:00 PM   #6
Rewards Points: 3,788
I think you're talking about the Goodman Comfortnet system which requires the use of a comfortnet thermostat to be fully functional which you do not have. The vision pro provides a slot for the sensor and it should be hooked there.
Your gas heat will be recognized as your back up or emergency heat and will only come on after a set number of circumstances which are programmed into the stat.
Bob Sanders is offline   Reply With Quote
Old 10-23-2015, 06:03 PM   #7
Rewards Points: 14
so do i need the all fuel board or can i take back
Old 10-23-2015, 06:07 PM   #8
Rewards Points: 14
so do i connect outdoor sensor to tstat or to the all fuel board
Old 10-23-2015, 06:14 PM   #9
The outdoor sensor gets connected right to s1 and s2 on the 8000
Old 10-23-2015, 06:18 PM   #10
Rewards Points: 14
ok thank you. is there anything special that i need to do to the all fuel board, as it too has a outdoor sensor connection.
Old 10-23-2015, 06:19 PM   #11
Rewards Points: 14
it has a factory jumper i it, says to break if using outdoor sensor
Old 10-23-2015, 06:31 PM   #12
With the visionpro you don't need any accessory boards. Just the thermostat
Old 10-23-2015, 08:38 PM   #13
Since you have the vision pro you don't need to do anything to the board. The board simply provides a certain level of control in case you are using a 'dumb' thermostat.... which you are not. The vision pro has the capacity to fully control everything so you don't need to use any of the control features on the board.
Problem with board or thermostat? HoldonLiz HVAC 1 02-18-2014 06:09 PM
Goodman Dual Fuel Heat Pump Rusty Bob HVAC 2 04-21-2012 08:00 PM
Moisture Barrier Behind AND on Top of Cement Board JasonCA Remodeling 0 04-07-2012 01:31 PM
installing hardy backer board for floor tile installation popeyemike Tiling, ceramics, marble 12 03-31-2012 03:02 PM
Goodman 4 flashes on control board bigmac71201 HVAC 6 09-28-2009 02:53 PM
