my furnace is not turning on, the light is flashing 3 times indicating a stuck open preasure switch. i do not have the # on it. does anybody have any suggestions on how to solve this probelm?
check for blocked vent pipes(flue pipe leading up from the furnace could be clogged),clogged hoses(check the hose from the inducer to the pressure switch and make sure it doesnt have a hole in it or a crack) and check the inducer to see if its bad. if the pressure switch isnt closing that means the inducer isnt pulling a vacuum. if you have a multimeter check for 120v from black to ground and white to ground.
I have a Goodman model GMNT 080 4B. The furnace start like normal but when the temperature reaches about 64 degrees I receive an error light. The fan continues to run but the burners do not. I have already tried cleaning the flame sensor but the problem continued. Tell me is anyone have any solution..?
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
