Old 02-09-2010, 05:50 PM   #1
Goodman gas furnace electronic ignitor
I have a older natural gas goodman Furnace PG0-60125-1AB
The filter got clogged and the unit shut down. After changing filter the unit would not ignite. Has a United Tech Electronic ignitor control.
Upon inspection, I found the burners had rusted over and were over 1/2 clogged so I tried to open eash port on a 5 Burner system. One of the burners had rusted so bad that it us fell apart and left a huge opening on the top of that burner. I put everything back and it still will not ignite. The blower runs continues but it will not ignite. The ignitor never tries to lite the furnace.
Any suggestions.
Russell
rperry is offline   Reply With Quote
Old 02-09-2010, 06:00 PM   #2
Sounds like the high limit switch is stuck open. Sometimes rapping on it with a screwdriver handle will fix it. Be careful with those rusted and holey burners, could cause a lot of serious problems.
SKIP4661 is offline   Reply With Quote
Old 02-09-2010, 06:57 PM   #3
An old Tradesmen
Don't run it until you replace those burners.
Old 02-09-2010, 08:20 PM   #4
If the burners are so rusted they fell apart the heat exchanger needs a serious check. IMO you're way past diy here, time to call a service company. Leave it off!
Old 02-10-2010, 05:39 PM   #5
Thumbs up
I am new to this type information board. The responses to my questions reflected what I thought.
Thank you for the different responses.
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Furnace's electronic ignitor NOT starting furnace rwtaylor48 HVAC 2 01-07-2010 10:14 AM
Goodman Gas furnace, A/C will not run new install RCApp HVAC 5 08-04-2009 10:00 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Goodman Furnace does not kick in wctoro HVAC 2 02-20-2008 02:47 PM
