Goodman Gas Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 11-09-2010, 06:47 AM   #1
Goodman gas furnace
I have a goodman furnace that will run a few cycles then shut down. When it stops there is a light on the computer board in the unit that blinks. It will blink twice then pause. Is this an error code or just an alarm on the board. I can take the door off (braking the switch) then ut it back on and the light stays on an the unit starts. It will run 3 or 4 cycles then shut down again. Any ideas or sugestions would be greatly areciated. I have paid two reairmen and dont want to pay another. the unit is about 6 years old. Thanks in advance
darrylbr is offline   Reply With Quote
Old 11-09-2010, 07:02 AM   #2
HVAC / Plumbing
look on the back of that door you took off & see what the code is
kenmac is offline   Reply With Quote
Old 11-09-2010, 07:15 AM   #3
Thanks I didnt even notice the alarm codes on the back. It says stuck or closed sensor. would that be the vacum sensor on the exaust fan?
Old 11-09-2010, 10:39 AM   #4
HVAC / Plumbing
is this an 80 or 90 + furnace ? I would check the ps
Old 11-09-2010, 12:50 PM   #5
Your rite it says preasure sensor closed. im not sure what the preasure sensor is.
Old 11-09-2010, 01:18 PM   #6
HVAC / Plumbing
do you know where the vent motor is ?. If you do. There is a small rubber hose connected to it. This hose connects to ps. Inspect the hose. Also, make sure the small port at the vent motor is clear
The Following User Says Thank You to kenmac For This Useful Post:
darrylbr (11-09-2010)
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Goodman Gas furnace, A/C will not run new install RCApp HVAC 5 08-04-2009 09:00 PM
Goodman Furnace gas firing but shuts off digitaljim HVAC 3 12-08-2008 03:29 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Goodman Furnace does not kick in wctoro HVAC 2 02-20-2008 01:47 PM
