-   -   Goodman gas furnace (http://www.diychatroom.com/f17/goodman-gas-furnace-86240/)
darrylbr 11-09-2010 06:47 AM
Goodman gas furnace
I have a goodman furnace that will run a few cycles then shut down. When it stops there is a light on the computer board in the unit that blinks. It will blink twice then pause. Is this an error code or just an alarm on the board. I can take the door off (braking the switch) then ut it back on and the light stays on an the unit starts. It will run 3 or 4 cycles then shut down again. Any ideas or sugestions would be greatly areciated. I have paid two reairmen and dont want to pay another. the unit is about 6 years old. Thanks in advance
kenmac 11-09-2010 07:02 AM
look on the back of that door you took off & see what the code is
darrylbr 11-09-2010 07:15 AM
Thanks I didnt even notice the alarm codes on the back. It says stuck or closed sensor. would that be the vacum sensor on the exaust fan?
kenmac 11-09-2010 10:39 AM
is this an 80 or 90 + furnace ? I would check the ps
darrylbr 11-09-2010 12:50 PM
Your rite it says preasure sensor closed. im not sure what the preasure sensor is.
kenmac 11-09-2010 01:18 PM
do you know where the vent motor is ?. If you do. There is a small rubber hose connected to it. This hose connects to ps. Inspect the hose. Also, make sure the small port at the vent motor is clear
