Goodman Furnance Stop Running - HVAC - DIY Chatroom Home Improvement Forum
Old 04-09-2010, 10:33 AM   #1
Goodman furnance stop running
I have Goodman GMT090-3B. It is stop running. I have check the control board and there is no indicator light. The power is ok from the breaker. The thermostat stop working since it is power through control board. Is the problem with control board. Do I need to replace it? Please advice. thanks.
Natth is offline   Reply With Quote
Old 04-10-2010, 09:25 PM   #2
well
check the transformer to see if you have 24 volts supplied at the secondary side, if not you have a bad transformer and that would explain no power to thermostat, reply back and let me know what ya come up with
tamar120 is offline   Reply With Quote
Old 04-11-2010, 12:23 PM   #3
biggles's Avatar
pull the stat off the subbase and jump R to G if you don't hear the supply fan or see a little spark the TR is shot.if you have a meter set to ohms "audible" and remove the 115V wires and the 24V side and ring them..if you don't hear anything on either or both sides the TR is shot.40/50 VA 115V/24V Grainger or HD,Lowe's
Old 04-11-2010, 10:28 PM   #4
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
check the 5a fuse on the board also
plummen is offline   Reply With Quote
Trane XE80 Furnace fan won't stop running Luv2Auction HVAC 2 01-07-2013 10:05 AM
RPJ2 Blower fan will not stop running number22 HVAC 8 07-19-2009 06:27 PM
Hot water won't stop running rickp47 Plumbing 8 02-19-2009 05:33 PM
Toilet won't stop running. 68MHJCs Plumbing 4 09-21-2008 01:03 PM
Freedom 90 furnance not running reliably from generator jrielsky HVAC 6 02-12-2008 02:48 PM
