Old 10-05-2012, 05:54 PM   #1
goodman furnace won't stay fired
I have a goodman updraft furnace, model gmvc80704bx. Occasionally, when it ignites, it only stays ignited for a few seconds, from 2 seconds to 10. It will continue to fire with the same results, until it shuts down completely. Most of the time it fires normally. Any ideas?
rjwhelehan is offline   Reply With Quote
Old 10-05-2012, 06:06 PM   #2
An old Tradesmen
Next time it does it, look for the error code, and see what error it is.
Old 10-05-2012, 06:11 PM   #3
error code 88 with 2 red flashes. It only happens once then returns to "OP" with a green flashing light.
Old 10-05-2012, 06:17 PM   #4
ok now I'm getting an E2 message which indicates a low pressure switch stuck open
Old 10-05-2012, 06:18 PM   #5
An old Tradesmen
Probably some moisture in the hose or switch. Could also be a build up of corrosion at the ports whee the hose attaches.
Old 10-05-2012, 06:19 PM   #6
do you have a manual?
is there a trouble shooting section?
Last edited by christoff; 10-05-2012 at 06:20 PM. Reason: posts were not up when i made my post
christoff is offline   Reply With Quote
Old 10-05-2012, 06:26 PM   #7
I just tapped on the low pressure switch and it fired normally. I'll try to clean the hoses and keep an eye on it.
Goodman furnace wont light and it is getting cold Rio_Grande HVAC 8 02-13-2012 08:01 AM
Goodman Furnace Model Number GMNT080-4 msgbob79 HVAC 15 12-28-2011 12:07 AM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Goodman Furnace Fail kod HVAC 6 11-17-2011 08:23 PM
Goodman furnace blowing lukewarm air mangust13 HVAC 12 02-19-2009 08:38 PM
