Old 02-12-2012, 05:40 PM   #1
Goodman furnace wont light and it is getting cold
Hello all
I have a furnace problem I hope you can help me with.
I have a goodman GMH 95
The thermostat calls for heat
THe furnace has 110v power to the unit
110 v through the door switch whan it is pressed and to the transformer
Transformer is sending out 28 volts to the board and nothing has power beyond that.
The LED on the board is not lit.
Of course this happens on Sunday when I cant get parts.
I think the transformer went bad and burnt up the board? does this sound correct?
I dont have any experience on this model. I was a pro with my old goodman because I had to work on it all the time but this one has been untouched but for filter changes for the 5 years we hav had it in the house.
Any information you have would be appriciated.
Rio_Grande is offline   Reply With Quote
Old 02-12-2012, 05:44 PM   #2
An old Tradesmen
Check the fuse on the furnace board. Also look for a short on the ow voltage side.
The Following User Says Thank You to beenthere For This Useful Post:
plummen (02-12-2012)
Old 02-12-2012, 06:05 PM   #3
how
List the age & model of the furnace.
How is the fuse on the board??
Was the led light on the board formally lit all the time even when there was no call for heat?
Have you confirmed that the thermostat is actually calling for heat?
Turn off the thermostat and jumper the thermostat leads in the furnace at connections R & W to confirm.
If you think that the board is fried then I'd turn off the power and pull it & carefully check the back of it for scorch marks.
Let us know what you find.
how is offline   Reply With Quote
Old 02-12-2012, 06:06 PM   #4
Thanks for the reply.
I forgot to put on that the fuse is not blown,
Where would I check for a short? I cant find power coming out of the board anywhere?
Thanks again for the reply
Old 02-12-2012, 06:20 PM   #5
the furnace is an 02 but it was not installed until 07 Guess it was sitting in stock somewhere. THe only number I could find on it is GMH950703BXAA
Fuse is not blown
I think it is on all the time but do not know for sure. The info on the inside of the door says if it is lit solid normal operation, if it is not lit bad control board.
The digital thermostat clicks and there is voltage out when it calls for heat.
I have not done this but I will
OK will do
Old 02-12-2012, 06:45 PM   #6
how
If the fuse is OK and the led is off then you probably have a broken connection in the board and not an active short.
Old 02-12-2012, 07:35 PM   #7
An old Tradesmen
Remove the wires from R and W, then wire a jumper across them, and see if it works then. Remember, the panel must be on for it to work, or the safety switch at least held in.
Old 02-12-2012, 07:40 PM   #8
HVAC Tech/ Browns Fan
You say that you was getting voltage from the transformer low side then fuse is ok. Did you try shut everything off and restart.
Tator1076 is offline   Reply With Quote
The Following User Says Thank You to Tator1076 For This Useful Post:
Old 02-13-2012, 08:01 AM   #9
been there done that
power in nothing out= bad board
dosy777 is offline   Reply With Quote
The Following User Says Thank You to dosy777 For This Useful Post:
plummen (02-13-2012)
Fixed pilot light, now furnace or AC won't turn on mjcfromct HVAC 2 10-17-2011 11:46 PM
Carrier Furnace with red tip to press down to help light gas furnace CinnamonFrye Appliances 1 09-18-2011 04:37 PM
Bubbling Toilet, Pilot Light in furnace out, extremely sick SewerBreath Plumbing 24 05-09-2011 07:38 PM
Pilot light going out often...and furnace making a big "boom" sound Beth777 HVAC 20 01-22-2011 05:27 PM
Goodman furnace control board patz83 HVAC 7 03-14-2010 03:07 PM
