Old 01-12-2010, 07:20 PM   #1
Question
Goodman furnace won't ignite.... help.
I have a Goodman GMPN120-5 furnace. Tonight I noticed that our house was getting quite cold and found that the furnace was not kicking on. I power cycled the furnace and listened to it's cycle. The exhaust fan turned on (vents though a pvc pipe to the outside) and ran for around 3 minutes and then shut off. I noticed that the ignitor never glowed as it should. I didn't smell any gas. I noticed something that looks like it may be a flame detecting sensor which lies in front of one of the metal tubes where the flame develops. Anyway, I noticed it looks pretty caked up with soot.
I checked the computer board in the furnace and the diagnostic light blinks three times, pauses and then repeats with three blinks then pause and so on.
I don't recall ever replacing the ignitor. It doesn't appear to be defective from what I can see. If I knew what the three blinking red leds represents that would help.
Any other ideas I should try?
It's supposed to get down in the teens tonight, so I need to get this fixed quick!
thanks
timrec is offline   Reply With Quote
Old 01-12-2010, 08:07 PM   #2
I think the light codes are listed inside the blower door.
Old 01-12-2010, 10:42 PM   #3
retired elect/hvac/plumb
plummen's Avatar
igniter heats up after inducer motor comes on,check your igniter for a crack.it will probably looklike a white line across one side.
plummen is offline   Reply With Quote
Goodman Gas furnace, A/C will not run new install RCApp HVAC 5 08-04-2009 10:00 PM
Goodman Furnace gas firing but shuts off digitaljim HVAC 3 12-08-2008 04:29 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Goodman Furnace does not kick in wctoro HVAC 2 02-20-2008 02:47 PM
Goodman GMP100-3 Forced Air Furnace Will Not Ignite Meerkat HVAC 4 02-05-2008 09:44 PM
