Goodman Furnace Trouble - Code 4 - HVAC - DIY Chatroom Home Improvement Forum
Old 01-02-2013, 12:25 AM   #1
Goodman furnace trouble - code 4
I have a goodman furnace Model # GDS80904BXBB. Intermittent problem with lighting. Code indicates open high limit. I was looking at the wiring and all looks ok - limit is closed ( voltage on both sides). When I followed the wiring to the control board and moved the connector it fired up and works most of the time. When it fails, pushing on the wiring block starts it again. The terminals look clean. Is the control board bad?
Mike12345678 is offline   Reply With Quote
Old 01-02-2013, 06:31 PM   #2
as seen on tv
Rewards Points: 150
Sounds like a bad cold solder joint on the board . Ring out the wires to make sure before replacing
qbert is offline   Reply With Quote
Old 01-02-2013, 08:05 PM   #3
Thanks, Is there a place I can get the part number based on the model of the unit? I couldn't make out the number on the control board.
Old 01-02-2013, 08:09 PM   #4
Rewards Points: 616
whoever sells Goodman will be able to tell you....
carmon is offline   Reply With Quote
Old 01-02-2013, 09:44 PM   #5
Rewards Points: 582
johnstone supply....ben sr
Goodman furnace F7 code freddray HVAC 3 10-30-2012 08:02 AM
Aprilaire 700A on Goodman Furnace? kcrossley2 HVAC 50 02-18-2012 05:41 PM
Goodman furnace error code 9 cool HVAC 2 12-11-2011 02:43 AM
Cobra Furnace - Trouble staying lit! Ican HVAC 13 01-29-2010 03:03 PM
Goodman furnace: won't start Guyver03 HVAC 2 10-23-2006 03:25 PM
