-   -   Goodman furnace trouble - code 4 (http://www.diychatroom.com/f17/goodman-furnace-trouble-code-4-a-167995/)
Mike12345678 01-01-2013 11:25 PM
I have a goodman furnace Model # GDS80904BXBB. Intermittent problem with lighting. Code indicates open high limit. I was looking at the wiring and all looks ok - limit is closed ( voltage on both sides). When I followed the wiring to the control board and moved the connector it fired up and works most of the time. When it fails, pushing on the wiring block starts it again. The terminals look clean. Is the control board bad?
qbert 01-02-2013 05:31 PM
Sounds like a bad cold solder joint on the board . Ring out the wires to make sure before replacing
Mike12345678 01-02-2013 07:05 PM
Thanks, Is there a place I can get the part number based on the model of the unit? I couldn't make out the number on the control board.
carmon 01-02-2013 07:09 PM
whoever sells Goodman will be able to tell you....
ben's plumbing 01-02-2013 08:44 PM
johnstone supply....ben sr
