Old 01-13-2010, 11:33 AM   #1
Question
Goodman furnace problem
My Goodman GMP075-3 furnace for the second floor of my home is acting up. Here's the pattern some of the time.
Thermostat calls for heat
Inducer fan starts- sometimes stops and tries to start again, sometimes runs and the ignitor starts lighting the burners. Will run for about 2 minutes the shuts down. Sometimes it will run for however long is necessary to satisfy the thermostat, sometimes not, and will shut down before reaching temp and then the inducer may cycle on and off not igniting the burners.
I suspect a control board problem, but sometimes the unit runs just fine.
It is in my attic I have checked the exhaust pipe and pressure switch/ no obstructions and working properly. Also tstat is AOK. Any ideas?
ACB2 is offline   Reply With Quote
Old 01-13-2010, 11:41 AM   #2
is the condensation draining away and not freezeing up somewhere attics are the worst possible place for a condensing furnace unless of course its heated
kennzz05 is offline   Reply With Quote
Old 01-13-2010, 02:57 PM   #3
The gmp is a standard efficiency furnace, does not condensate. Next time it fails get the number of flashes, if any, from the circuit board diagnostic light.
SKIP4661 is offline   Reply With Quote
Old 01-13-2010, 06:17 PM   #4
Question
There are no flashes from the diagnostic light. It is constantly on. I think I mentioned that it does occasionally run through the cycle without a hitch, though the most noticable problem (other than lack of heat) is when the inducer fan seems to start and stop, or fail to run properly at the beginning of the cycle. It may just tick on and off for anywhere from 1 to 5 seconds before cycle failure. But no light on the board to indicate the failure.
Old 01-13-2010, 07:09 PM   #5
It could be a thermostat problem. The best way to check this is to by-pass the thermostat. To do this you need to connect the white and red wires together, either at the thermostat or furnace. If when by-passed, the furnace fires and runs replace the thermostat. If it doesn't work right it could be a loose wire, high or low voltage, check the plugs and connections. It could be a board but maybe not.
The Following User Says Thank You to SKIP4661 For This Useful Post:
Laurie27 (11-06-2010)
Old 01-13-2010, 10:32 PM   #6
Question
Thanks. I have two of the same type t-stats (other is in use for the first floor furnace, and that works without problems) and I have swapped them with the same result. I will try the by-pass just to confirm though.
Heil Furnace Burner Problem timothyr HVAC 78 01-18-2013 07:49 PM
Goodman Furnace gas firing but shuts off digitaljim HVAC 3 12-08-2008 04:29 AM
goodman HVAC problem...only runs on AUX mode kerbear413 HVAC 1 12-03-2008 12:51 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
goodman furnace nhicks HVAC 3 02-09-2008 07:25 PM
