Goodman Furnace Not Starting - HVAC - DIY Chatroom Home Improvement Forum
Old 03-29-2010, 09:07 AM   #1
Goodman Furnace not starting
Hey Guys,
I have a Goodman furnace GMP125-4 unit that when I call for heat, the igniter will glow first (strange), but, none of the other processes start. I.E, the inducer does not come on first, or at all. I get a steady light sequence (no blinking) from the ckt. brd LED. The fan will not run, when the the TS control is switched to manual.
BTW, the conrol brd. was replaced a few months ago.
Please, any help before I get a bigger hammer!
Thanks,
Ken
SilverBullit is offline   Reply With Quote
Old 03-29-2010, 10:09 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,756
Was it replaced with a Genuine Goodman board and not a knockoff. Very important that the furnace be grounded properly or it will blow circuit boards. The mounting plate for the board on the fan comes loose (loses ground) and needs to be secured with larger sheet metal screws.
Old 03-29-2010, 10:24 AM   #3
Thanks for the reply. The board was replaced by an ICM Controls product and is listed as an ICM280C Goodman Furnace Control module. The starting sequence started acting up a few days ago, with doing a couple start-up cycles before finally continuing to the run cycle. Last evening it finally stopped. The brd. mtd. on nylon legs, but, I will check for any loose ground. I did check the filter and it was a little clogged. After cleaning, I checked the limit sw and it was not tripped.
Old 03-29-2010, 11:14 AM   #4
Hvac Pro
yuri's Avatar
Check for ground from the furnace AND that mounting plate to a copper water line. Use a piece of cheater wire from the water line to your ohmeter and then furnace (trick of the trade).
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Goodman Gas furnace, A/C will not run new install RCApp HVAC 5 08-04-2009 09:00 PM
Starting up a goodman furnace MikeS HVAC 6 12-10-2008 07:42 PM
Goodman Furnace gas firing but shuts off digitaljim HVAC 3 12-08-2008 03:29 AM
Goodman furnace not starting cathyfc HVAC 1 10-05-2005 11:35 AM
