Goodman Furnace Model # Gmt070-3a Serial # 0303602933 - HVAC - DIY Chatroom Home Improvement Forum
Old 10-08-2011, 03:36 PM   #1
goodman furnace Model # gmt070-3a Serial # 0303602933
My furnace tries to fire up it fires three times and then locks up. I have tried to clean up the flame sensor rod but still the same thing. It has a 1 blink code and I need to know how to check anything else. Thank you.
wickwicky is offline   Reply With Quote
Old 10-09-2011, 02:21 PM   #2
biggles's Avatar
if you have Induced draft feeding the firnace thats the sma;; motor that runs to supply chamber air...there is a pressure switch 4" silver round with 2 wires going to it it might be bouncing causing the 3x lockout relite check the tube sensing the air discharge on the blower.....again this isn't the furnace supplt fan so you know.... check you grounding of the ignitor might be rusted and not making contact...do you hear a snapping when it it trying to light like your stove burner when you turn it on?
Old 10-09-2011, 02:35 PM   #3
I don't hear any popping or whistling. The flames come on for like 5 or 10 seconds then shuts off. It does that 3 times then doesn't even try to light again. Then the light blinks saying there is a problem.
Old 10-09-2011, 03:18 PM   #4
JJboy's Avatar
1- Disconnect the power
2- Connect the multimeter in serie with flame sensor ( set multimeter in DC amp)
3- restore power and call for heat
4- Read the flame current level....should be not less than .8 microamp.
5- replace frame sensor
SEE PAGE 56 SERVICE MANUAL
You already asked this.
furnace not staying lit
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 10-15-2011, 03:35 PM   #5
Thanks to all who posted. Not sure exactly what it was but after trying everything n testing I now have heat. Thank you to all.
Goodman Furnace GMPN100-4 ignition question jomo795 HVAC 8 11-14-2010 02:13 PM
goodman furnace sputter ttt2340 HVAC 10 11-07-2010 09:42 AM
Goodman furnace control board patz83 HVAC 7 03-14-2010 02:07 PM
Goodman furnace: won't start Guyver03 HVAC 2 10-23-2006 02:25 PM
Goodman furnace not starting cathyfc HVAC 1 10-05-2005 11:35 AM
