Goodman Furnace LED Fault Light - HVAC - DIY Chatroom Home Improvement Forum
Old 10-25-2011, 08:54 AM   #1
Hi - My Goodman furnace would not start the other day. I could here it trying, then after taking the panel off saw the LED flashing 8 times which meant a polarity issue. So I pulled the transformer, cleaned contacts, etc... tested voltage then it fired right up.
However, now its shut down again with a single flash which means the flame detector is faulty. So I cleaned it up, but now the damn light won't reset!
The code says that the system is on lockdown and that it will retry in 1 hour. Or you can turn off the power, etc.. to reset it. I've tried everything, I can't get it to turn back on.
Any ideas?
Sam Gribley is offline   Reply With Quote
Old 10-25-2011, 02:16 PM   #2
Hi - I got it to work. I swapped the flame sensor and its been running fine.
Pilot light going out often...and furnace making a big "boom" sound Beth777 HVAC 20 01-22-2011 04:27 PM
Ducane furnace does not light. uncleshah HVAC 7 02-08-2009 06:44 PM
Goodman GMP100-3 Forced Air Furnace Will Not Ignite Meerkat HVAC 4 02-05-2008 08:44 PM
Goodman GMT-070-4 Furnace blows 3A Fuse Bruce Mundy HVAC 4 01-02-2008 10:31 PM
Furnace won't light Babybird HVAC 2 03-30-2007 09:48 AM
