Goodman Furnace GMPN100-4 Ignition Question - HVAC - DIY Chatroom Home Improvement Forum
Old 11-06-2010, 10:21 AM   #1
Goodman Furnace GMPN100-4 ignition question
My GOODMAN GMON100-4 is having trouble starting. The ignitor visually looks to be in good shape. The unit will kick on, the circuit board will click to light the ignitor. I have watched 3 things happen. Sometimes the Ignitor glows orange and fires up, and sometimes it won't glow at all, and sometimes is glows then dies before the gas kicks on, and it may glow and start the unit on the next attempt during the starting cycle. As you probably know, the unit will cycle through 3 start attemps, and then will shut itself down and wait for a reset.
I just pulled the board out and cleaned all the contacts on the board. The furnace now kicked on 3 times in a row on the first try with the ignintor glowing super-orange! I will assume the board is probably going as it is about 17 years old. I looked on-line and the replacement boards specified for my model are not the same configuration as what is in my Goodman. One major difference is a 9 pin DIN connector on the new board that is not on mine. Can I follow the same schematic that I have with my heater and move it to a new board easily or should I bring someone out to rewire the machine? The unit is still very clean and in really good shape!
Thanks for any advise you can give.
jomo795 is offline   Reply With Quote
Old 11-06-2010, 11:28 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,240
The igniter may be dying. Check it with an ohm meter when it is cold. Should be between 40-80 ohms. If it is OK then the replacement board is a retrofit and they should include a cable and instructions with it. Buy it from a reputable dealer, not zbay. There were heat exchanger cracking issues with those units so it should be properly inspected by an experienced tech.
Old 11-06-2010, 11:42 AM   #3
Thanks yuri. The unit is back and forth again. I'll try the ohm meter and if not good I will order a board. I saw one on allpartsheating.com. Is that a good place?
Old 11-06-2010, 11:54 AM   #4
Hvac Pro
yuri's Avatar
search: homeairdirect, one of our buds and should know how to cross reference it and answer your questions.
Old 11-06-2010, 01:24 PM   #5
Cold is 110 ohms.
Old 11-06-2010, 02:36 PM   #6
Hvac Pro
yuri's Avatar
If it is a approx 1" wide black type then it should not be more than 75 ohms, usually around 50-55 ohms. If it is a much smaller/skinnier one then I don't know the ohms on them but I doubt they are more than 90 as that is what the Lennox use. Sounds like yours is cracked and barely holding together and intermittently completing its circuit. High ohms indicates too much resistance/cracked. Try a new one B4 changing anything else. 1st pic is the regular one, 2nd is newer smaller version. PS, they are INCREDIBLY fragile, look at them the wrong way and they break. Hope you have soft hands. The universal ones don't always fit the Goodmans so I would try get the OEM one as it has a special slot/ridge on it.
Old 11-06-2010, 04:11 PM   #7
It is the black one and thanks alot for the direction! I'll let you know!
Old 11-10-2010, 08:00 PM   #8
AKA HVACTECHFW
Rewards Points: 1,208
known for cracked heat exchangers!
hvactech126 is offline   Reply With Quote
Old 11-14-2010, 02:13 PM   #9
Replaced the board and the ignitor. Runs great.
Gas furnace exhaust vent question nowell HVAC 7 01-30-2012 08:31 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
Rollout on Goodman Condensing furnace jogr HVAC 11 11-20-2008 08:30 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
another question for a miller furnace problem jb9270 HVAC 1 02-05-2007 02:04 PM
