Old 01-12-2011, 09:06 PM   #1
Goodman Furnace Delay?
Recently, I've noticed that my Goodman gas furnace connected to a Honeywell VisionPro 8321U1006 programable thermostat will run for a while, shut off, then immediately start back up. This often occurs several times in a row.
Is this normal? Does the VisionPro have a programable delay? If this isn't normal operation, how do I fix it?
Thanks!
kcrossley2 is offline   Reply With Quote
Old 01-12-2011, 09:10 PM   #2
HVAC / Plumbing
No it's not normal. how old is t.stat
kenmac is offline   Reply With Quote
Old 01-12-2011, 11:11 PM   #3
About 3 years.
Old 01-13-2011, 05:34 AM   #4
An old Tradesmen
Problem is probably in the furnace, or its venting.
Old 01-13-2011, 07:34 AM   #5
So, that means the furnace computer should indicate an error when put in diagnostics mode. correct?
Old 01-13-2011, 07:59 AM   #6
HVAC / Plumbing
It may or may not.. It could be T.stat but, not likely. You can eliminate the T.stat by jumping the R & W wires. If it's not T stat you will have to check other things such as Air flow. causing limit to shut down furnace .When was your return filter replaced ?
Aprilaire 700A on Goodman Furnace? kcrossley2 HVAC 50 02-18-2012 05:41 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Goodman Gas furnace, A/C will not run new install RCApp HVAC 5 08-04-2009 10:00 PM
Goodman Furnace gas firing but shuts off digitaljim HVAC 3 12-08-2008 04:29 AM
Goodman Furnace does not kick in wctoro HVAC 2 02-20-2008 02:47 PM
