Originally Posted by hvac122
Check the voltage between c and r at the furnace. Should be 24. Then check the voltage between c and w at the furnace with a call for heat. Should be 24v.
Let us know what you come up with.
Also during all of these tests make sure the door switch is made.
I have 4 wires coming from the furnace. Red (t-former)= 24vac, White (control/heat), Green (fan), Blue (used as yellow to AC)
Red to Ground at the t-stat is 26.6vac and the same at the furnace.
White to Ground with a call for heat is also 26.6vac
AC settings work as expected as does the fan only setting.
Originally Posted by raylo32
I would double check your stat wiring. At the furnace board you should see ~24VAC across red to common all the time and across white to common on a call from heat. Not sure why you have 24V across red and white?
Double and triple checked. tried running nothing but the Red White and Green wires without the blue to AC condenser just in case. I even put the original mercury dial t-stat back on with no better results.
I did not type exactly what I wanted to say in my original post. I meant to say that I have 26.6vac at the Red wire as expected therefore confirmation that the t-former is operating correctly and when jumped to the White wire, I still get nothing.
Originally Posted by beenthere
If the thermostat was calling for heat, and you read 24 volts across R and W, then either a wire is broke, or the thermostat is bad, or not set up right.
As said above, with the thermostat calling for heat, check for voltage between W and C/common.
See above two answers. I knew what I was thinking but by time it reached my fingers it was convoluted.
Originally Posted by ben's plumbing
you can unwire stat wires off control board..and jump between r-w see if starts this will by pass thermostat.....ben
Tried this also. When I jump them all I get is a click, then nothing but the faint hum of electricity flowing
A bit of new info though... in my original post I had said that I had checked the roll-out switches but I had only checked that none of the four had tripped, and they hadn't. I went back to check continuity across the switches and found nothing. I get nothing in or out of any of the four switches with the t-stat calling for heat or not.
With all else functioning as expected, 26.6vac, continuity everywhere I have checked except for the rollout switches, AC and fan functions working, steady LED with no fault codes... is the next assumption going to be that the board is shot?
