Goodman Furnace...dead? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-22-2011, 09:26 PM   #1
goodman furnace...dead?
I tryed to start my furnace to make sure it`s ready for winter and nothing. So I checked the status light and it was off. The 3 amp fuse is good. Help would be appreciated. Thanks, Gene.
dible62 is offline   Reply With Quote
Old 09-22-2011, 10:10 PM   #2
You are going to need to check the transformer voltage.
Master of Cold is offline   Reply With Quote
The Following User Says Thank You to Master of Cold For This Useful Post:
dible62 (09-25-2011)
Old 09-23-2011, 04:24 PM   #3
transformer voltage
Thank you for your responce. I checked the transformer voltage.The red wire 28, black 124.
Old 09-23-2011, 04:35 PM   #4
JJboy's Avatar
Transformer is good. Furnace has a safety switch that you need to close it when the front cover is pulled off.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
The Following User Says Thank You to JJboy For This Useful Post:
Old 09-23-2011, 04:53 PM   #5
If you are getting 24v that means he board is recieving 120v. Check to make sure that you have a ground. Check the green wire. If you have good ground. Then your board are bad
Mr.HVAC is offline   Reply With Quote
The Following User Says Thank You to Mr.HVAC For This Useful Post:
Old 09-23-2011, 05:02 PM   #6
biggles's Avatar
standing pilot,induce draft solid stat board within furnace...stat is heating only system in heat mode....remov stat jusmp R to W see if you get a cycle
The Following User Says Thank You to biggles For This Useful Post:
Old 09-23-2011, 06:15 PM   #7
The ground looks good.
Old 09-23-2011, 07:15 PM   #8
If you are sure that you have a good ground. Then I am afraid it is your board. But before replacing the board, replace the 3 amp fuse (even tho it looks good) and recheck all your ground wires From the electrical outlet to the furnace. Most circuit board will not function properly unless it has a good ground.
If noone work on this furnace before it died, then most likely your board is bad.
Old 09-23-2011, 07:50 PM   #9
Dead furnace?
The truth is, when I went to check the ground I noticed that the ground wasn`t even hooked up..... They had cut it off when they installed the furnace. I ran the furnace for 5 years without a ground.
Old 09-24-2011, 12:06 PM   #10
There we go, try to connect the ground back in again and see if it works. Ground wires are there for a reason, to protect circuit. It might have worked fine for 5 years, but it may also burned the board because it has no ground. Some board will work without ground for a while, but end up damaging components and some will not function properly unless it has a good ground... For some odd reason, I have a felling that your board is bad. Try reconnect ground wires and reset the whole house breaker, see if that works. if that doesn't work, replace board and make sure ground wires are connected.
Old 09-24-2011, 12:26 PM   #11
biggles's Avatar
brand new the mounting screws should also ground unless you push it down on those plastic pins to hold it in place
Old 09-24-2011, 08:04 PM   #12
I hooked up the ground wire and still nothing. Does that mean the board is bad?
Old 09-24-2011, 08:06 PM   #13
If you have replaced the fuse (even if looks good), and the board doesn't light up, it dead.
Old 09-24-2011, 08:11 PM   #14
Would you know the cheapest place to buy a control board?
Old 09-25-2011, 09:33 PM   #15
Bibles, you might want to try to google it. Sorry, I don't buy parts online as I have connections from locals. Good luck with everything and let us know how it's doing.
dible62 (09-26-2011)
pro and con goodman furnace and ac leiut56 HVAC 8 07-24-2011 06:43 PM
Help Needed. Goodman furnace jzw HVAC 14 01-01-2011 11:21 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Goodman Furnace GMNT100-4b Won't stay on freeslporer HVAC 3 10-30-2008 06:42 PM
Goodman furnace: won't start Guyver03 HVAC 2 10-23-2006 02:25 PM
