Goodman Furnace Code 8? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-30-2008, 11:43 AM   #1
Hey everyone. I installed a goodman GMH80453 the other day. On the day of install I started and ran it twice with no problems. Now it won't run. Series of events are....Turn up stat to kick it on, inducer fan comes on, runs for about 10 seconds..Then click shuts down and flashes a
code 8(which is not listed in manual). The ignitor never glows. I don't see any burn spots on the board and 3amp fuse on board is ok. I can flip the power off then back on and it will go through the same series. Has anyone ever had this problem? Any Ideas? Please help a diy'er out! Any Input would be great. Thanks!
short1 is offline   Reply With Quote
Old 09-30-2008, 09:16 PM   #2
If the code isn't listed, go the old fashioned way. Is the inducer motor pullng shut the pressure swith. Are there any limits or safeties open. Is there power going to the hot surface ignitor?
Buckeyetech is offline   Reply With Quote
Old 10-01-2008, 01:10 AM   #3
Thanks, figured it out, it was the ignitor.
Carrier Furnace help code 31 fauxjaux HVAC 6 04-22-2010 11:36 PM
Goodman Furnace does not kick in wctoro HVAC 2 02-20-2008 02:47 PM
goodman furnace nhicks HVAC 3 02-09-2008 07:25 PM
Goodman furnace: won't start Guyver03 HVAC 2 10-23-2006 03:25 PM
