Goodman Furnace/AC - HVAC - DIY Chatroom Home Improvement Forum
Old 09-25-2009, 03:44 PM   #1
goodman furnace/AC
Our vacation condo in Nevada will sit empty for months at a time. In the summer i keep the thermostat on cool and HOLD at 90 degrees and for the cooler months i leave the thermostat on heat and HOLD at 50 degrees. My question is... Can i trun off the main water shut off coming in to the condo and still have my Goodman furnace/AC run properly? Does water have any function whatsoever for the proper operation of a furnace/AC? Thank you.
duster is offline   Reply With Quote
Old 09-25-2009, 05:19 PM   #2
An old Tradesmen
Rewards Points: 6,922
Not for a regular forced air system.
But, if you think shutting off the water willhelp to prevent water damage.
Not really, since your pipes will still have water in them.
Old 09-25-2009, 06:42 PM   #3
Granted, a busted pipe may cause some damage, but wouldn't the damage be considerably worse if the lines were live while the premises was un-occupied?
Flashheatingand is offline   Reply With Quote
Old 09-26-2009, 03:47 AM   #4
An old Tradesmen
If the shut off is in another space that is conditioned. Then yes.
Old 09-26-2009, 01:03 PM   #5
ty for the advice
Nordyne condenser goodman A-coil wtroger HVAC 10 09-16-2009 03:52 AM
Evaporator coil for Goodman A/C leschuler HVAC 2 09-25-2008 12:43 PM
goodman furnace nhicks HVAC 3 02-09-2008 06:25 PM
Replacing an 20 year old gas forced air with a 95% 2 stage goodman, goodman 40" tall, englewood1 HVAC 12 09-25-2007 11:37 PM
Sub is swapping Amana for Goodman Dragon HVAC 22 02-04-2007 07:54 AM
