Goodman Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 10-26-2012, 08:42 PM   #1
Goodman Furnace
Goodman Model #JMNT1205D (another goodman POS) I have power to furnace, inducer motor comes on and I get 24v to both sides of PS but no 24v coming out of 9 pin plug to Aux. LS, RS, etc. I also loose the diagnostic light on the board and unit does not try to restart. Blower motor was set to on and works fine. Sounds like a bad board. Any advise?
gomjo1 is offline   Reply With Quote
Old 10-26-2012, 08:51 PM   #2
JJboy's Avatar
Sounds like an exhaust clogged or bad pressure switch. You should measure 0V at pressure switch in order to glow the igniter.....
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 10-26-2012, 09:08 PM   #3
Actually you should get 24v to each side of the PS terminals to ground, which I do have.
Old 10-26-2012, 09:45 PM   #4
I'm Your Huckleberry
Rewards Points: 2,270
You should get 24 volts to ground on any hot 24 volt line but that's not what he said. 24 volts to ground simply means that there's the potential for said 24 volts to travel to ground if given a path to do so from the original line you're testing. If you have it on both sides than most likely the pressure switch is closed but I'd test it across the switch as well to prove there's 0 volts, closed. He meant across the pressure switch it should not read 24 volts meaning the switch is closed.
Thanks.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
ben's plumbing (10-27-2012)
Old 10-26-2012, 09:48 PM   #5
Is the ignitor glowing or not?
Thanks.
Old 10-26-2012, 10:10 PM   #6
No it is not. Shouldn't the unit try the times before going on lockout? Also, why wouldn't I get 24v from my 9 pin connector to my ALS?
Old 10-26-2012, 10:34 PM   #7
Rewards Points: 616
easy... just trying to help.... it sounds like the board can you post picture of wiring diaghram
carmon is offline   Reply With Quote
Old 10-26-2012, 10:54 PM   #8
No I don't have it with me but I do know that ICM has a 9 pin connector and tracing the wires I know there is a aux pressure switch on the Induced draft motor that gets power from pin 5 which I have no voltage coming out to the ALS. Tried bypassing ALS and still nothing. Rollout switches (4) are all in series after that. No voltage to ground on all for rollout
Old 10-26-2012, 11:13 PM   #9
Rewards Points: 616
wiring would help ... will look at shop in morning should have it there......
Old 10-27-2012, 01:18 AM   #10
Have you ohmed out the ignitor? Tested voltage to the ignitor?
Thanks.
Natural Gas Cost For Furnace 1 Hour Run Time hammerlane HVAC 25 01-14-2015 02:13 PM
Goodman furnace dead? jtobias HVAC 14 11-04-2011 03:34 PM
pro and con goodman furnace and ac leiut56 HVAC 8 07-24-2011 06:43 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
