Goodman Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 09-30-2011, 06:07 PM   #1
goodman furnace
I have a goodman furnace. My ignitor is fine but the flames only stay on for a few seconds. Venting seems to be ok
bill a is offline   Reply With Quote
Old 09-30-2011, 06:33 PM   #2
JJboy's Avatar
Clean flame rod
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 09-30-2011, 11:27 PM   #3
I'm Your Huckleberry
Rewards Points: 2,270
Flame sensor. If it doesn't sense a flame the unit will cut the heat off. You need a good ground wire to the unit so make sure that the ground wire is present and tight to the cabinet.
We're talking micro amps.
Doc Holliday is offline   Reply With Quote
pro and con goodman furnace and ac leiut56 HVAC 8 07-24-2011 06:43 PM
GOODMAN 100-3 Forced Air Furnace problem lindatbird HVAC 4 11-10-2010 08:55 PM
Goodman Furnace not starting SilverBullit HVAC 3 03-29-2010 11:14 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
