#1 |
goodman furnace
Ihave a goodman furnace that starts to cycle even when the thermostst is turned all the way down. Any ideas
#2 |
Professional
goodman furnace
remove the red wire from the stat. If it stops cycling without a call for heat then it is the stat. If it still does it then remove the red wire from the control board. IF it then quits it is the wiring between the stat and the board. If it continues to cycle then it is the control board.
IT IS WHAT IT IS To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| Display Modes | |
| Water Inside/Around American Standard Furnace | michrob | HVAC | 8 | 12-08-2011 04:51 PM |
| Goodman Gas furnace, A/C will not run new install | RCApp | HVAC | 5 | 08-04-2009 10:00 PM |
| Goodman Furnace gas firing but shuts off | digitaljim | HVAC | 3 | 12-08-2008 04:29 AM |
| New Cased Coil - Install to Furnace - PICTURES!! | hartkem | HVAC | 39 | 11-18-2008 02:45 AM |
| Goodman Furnace does not kick in | wctoro | HVAC | 2 | 02-20-2008 02:47 PM |
