Goodman Fan Will Not Come On With A/C - HVAC - DIY Chatroom Home Improvement Forum
Old 07-04-2011, 12:02 AM   #1
Question
Goodman fan will not come on with A/C
I have a Goodman GMP075-3 Serial # 9401003861. When I turn on the A/C unit the outside unit comes on but the Goodman blower motor on the furnace will not start. I called a tech out and he got it started and said it was the relay on the control board but he did not replace the board. He tapped it and said 90% of the time that would take care of the problem.
But the next day the blower motor would not start again. (During the heat of the day, the attic gets hot and that is when the blower won't start. It does seem to start at night when the attic cools down.)
The tech indicated that if I still have the problem the board will need to be replaced at $325. Is that a reasonable cost or can I buy a board for this unit and replace it myself? How would I go about replacing the board? Thanks for the help! Jim
Binski is offline   Reply With Quote
Old 07-04-2011, 05:57 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 92
If it does not start the AC will freezeup and will get damaged. Get it replaced ASAP and the price is reasonable. The tech is a bit of a dope, tapping the relay NEVER solves the problem just delays it.
Old 07-04-2011, 10:40 AM   #3
Thanks I feel better about it.
Goodman air handler adjustment Xander08 HVAC 2 12-24-2009 02:32 PM
Nordyne condenser goodman A-coil wtroger HVAC 10 09-16-2009 03:52 AM
Evaporator coil for Goodman A/C leschuler HVAC 2 09-25-2008 12:43 PM
goodman furnace nhicks HVAC 3 02-09-2008 06:25 PM
Sub is swapping Amana for Goodman Dragon HVAC 22 02-04-2007 07:54 AM
