Old 01-25-2013, 07:10 PM   #1
Goodman dual unit
Is changing the balancing point something easy to do? I rent a home that had a new Goodman Dual unit put in feb 2012. I filled up a 100 gallon tank then. That lasted until December 16th 2012. From my understanding that heat pump will be on until it drops below 40 degrees and then the propane will kick on. I checked my gas on MOnday and had 30% checked today and only had 5%. I filled the tank up again on the dec 16th for $320, and called today and it was going to be $480. So basically I have a power bill of $150-$175 and a high gas bill that last a little over a month. I am thinking if I put the balance point to 25-30 that would decrease the gas bill, and it wouldn't cost me as much every month with the power and gas. Also if I run out of gas can I still use the unit just with the electric?
mandyseghs is offline   Reply With Quote
Old 01-25-2013, 07:21 PM   #2
Goodman dual unit
Wow. Seems to me like electric backup heat would have been the way to go, propane isnt cheap.
Which thermostat, controls does the unit have?
sammy37 is offline   Reply With Quote
Old 01-25-2013, 08:19 PM   #3
An old Tradesmen
Goodman dual unit
Most thermostats will allow you to set the balance point much lower.
Amana ASX14 vs Goodman SSX14 photosaver99 HVAC 11 10-09-2012 08:48 PM
Newly installed AC unit not working skye24F HVAC 10 09-29-2012 07:08 PM
4 ton 13 seer goodman A/C & gas furnace unit Laurence Foster HVAC 8 06-10-2010 09:11 AM
Goodman GMPN100-4 oneam HVAC 16 02-28-2010 04:58 AM
goodman HVAC problem...only runs on AUX mode kerbear413 HVAC 1 12-03-2008 12:51 AM
