Goodman CPLE24-1C A/c Tripping Breaker - HVAC - DIY Chatroom Home Improvement Forum
Old 05-20-2012, 03:34 AM   #1
Goodman CPLE24-1C a/c tripping breaker
Hello all,
As it is starting to warm up we started to run our A/C and noticed it wasn't cooling the house. The fan was blowing so I went down and checked the breaker and sure enough the two 30amp breakers for the A/C were tripped. I flipped it and it held for a second and tripped again. Multiple attempts resulted in the same outcome, it would trip within seconds. I went outside and pulled the disconnect switch, went back and flipped the breaker, and it held. So I go back outside and reinstall the disconnect switch. I hear a slight humming sound and then a little click. After returning to the basement I see that the breaker has tripped again.
One thing of interest is that all this happened with the A/C turned OFF at the thermostat. If the thermostat was set to A/C the breaker trips even faster and even sparks.
I am a first year electrical engineer student who was recently laid off from work. So needless to say I would really like to try to diagonse this issue myself for financial and knowledge reasons. Thanks in advance for any assistance guys
BraDolMag1 is offline   Reply With Quote
Old 05-20-2012, 07:16 AM   #2
Start with a visual inspection looking for burn marks or mouse chewed wires. If it's not that break out the meter and see which component is shorted to ground.
Tags
air conditioner , breaker , central air , goodman , trip
One breaker tripping another armisjam Electrical 12 03-09-2012 09:43 PM
Slow tripping breaker phishfud Electrical 10 02-01-2012 06:53 PM
Main Breaker is tripping rdmccaw Electrical 18 02-05-2009 11:27 PM
Tripping Wrong Breaker woodworksnmore@comcast.ne Electrical 15 03-28-2008 02:47 PM
HW tank breaker tripping arichard21 Electrical 6 10-31-2007 05:13 PM
