Goodman Compressor Stopped - HVAC - DIY Chatroom Home Improvement Forum
Old 08-11-2009, 01:09 PM   #1
Goodman compressor stopped
Hello, I have central AC- Heating system by LUXAIRE. The compressor is Goodman Model CK36-18. The power and thermostat control are OK, the contactor on the compressor is OK and triggered. Wiring is OK and compressor fan is freely rotating by hand. Compressor is not spinning and there is no sound. Please help.
Thanks a lot.
Felix.
FelixU is offline   Reply With Quote
Old 08-11-2009, 01:44 PM   #2
Thanks a lot.
Felix.
Is there voltage on the compressor side of the contactor?
If yes, then check the start and run caps, relay, or compressor overload and/or compressor winding being open.
If there is no voltage on the compressor side is there voltage on the line side. If yes, then check contactor failure and any hi/lo cut out/lock outs.
You're dealing with live high voltage connections so be extremely careful or consider hiring a pro.
hennyh is offline   Reply With Quote
goodman HVAC problem...only runs on AUX mode kerbear413 HVAC 1 12-02-2008 11:51 PM
Evaporator coil for Goodman A/C leschuler HVAC 2 09-25-2008 12:43 PM
goodman furnace nhicks HVAC 3 02-09-2008 06:25 PM
Replacing an 20 year old gas forced air with a 95% 2 stage goodman, goodman 40" tall, englewood1 HVAC 12 09-25-2007 11:37 PM
Sub is swapping Amana for Goodman Dragon HVAC 22 02-04-2007 07:54 AM
