Goodman ComfortNet Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 11-10-2011, 01:52 PM   #1
Need heat only; will this combo work? Have Goodman gas 2 stage Variable speed furnace model GMVC950704CXAB with CTK01 Thermostat without A/C compressor.
Will the Comfort Net 4 terminal connections R, C, and Data 1, 2 connected at thermostat and furnace run the heat without A/C unit connected? L
Low voltage cable shielded 4 wire with ground terminated with 4 position plug connectors both ends. Are any jumpers required and from ? to ? Cable ground wire connection to any teminals or just to furance frame/ thermostat box?
Len Mediavilla is offline   Reply With Quote
Old 11-10-2011, 03:39 PM   #2
Rewards Points: 6,652
Can you please explain in better wording, in what you are asking about?
Old 11-10-2011, 05:02 PM   #3
Yes, it will run it without an outdoor unit connected. Make sure your furnace is on a dedicated line voltage circuit and is properly grounded. It won't require shielded cable, a piece of 18/5 stat wire is fine. Hook up your four pin harness from the furnace to the thermostat. It's as simple to wire as any stat available. The ONLY thing you have to ground is the furnace to it's dedicated line voltage circuit, nothing on the 24V side.
brandonmcginnis is offline   Reply With Quote
Goodman heat not engaging with new thermostat autosay97 HVAC 13 10-17-2010 08:37 AM
Goodman Heat Pump 2 Thermostat Wiring RanLoot Electrical 1 05-09-2010 07:20 AM
thermostat for goodman gmvc950453bx pedro1980 HVAC 4 03-17-2010 06:05 PM
Problem: Goodman GMNT to Hunter 44155C Thermostat shipupride HVAC 5 10-11-2009 04:36 PM
A/C won't turn off with thermostat temp adjustment ( Goodman system ) rkpatt HVAC 3 07-29-2008 04:58 PM
