Goodman CK36-1T A/c That's Missing A Piece!! - HVAC - DIY Chatroom Home Improvement Forum
Old 05-30-2011, 02:56 PM   #1
Goodman CK36-1T a/c that's missing a piece!!
Hi,
The previous homeowner purchased this mobile home that was supposed to have central air. They brought the unit out and set it on the ground, then when the serviceman came to hook up, he said something was missing. The previous owner doesn't know what's missing, but I have a sneaking suspicion that it goes in the pictured spot. Can anyone tell me what's missing and if I should try to replace it or just sell the unit for scrap?
Thanks,
1horsefarm is offline   Reply With Quote
Old 05-30-2011, 03:08 PM   #2
JJboy's Avatar
Contactor
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 05-30-2011, 03:28 PM   #3
Contactors aren't very expensive, but a missing contactor could indicate a very old unit. I have had a hard time finding info on the internet for CK36-1T and can't even find listings on the internet part stores. The unit hasn't even been hooked into the house yet, so I would have to have that done. The only info I see about the models is that they are junk after 5 years. Is that true?
The unit has also been sitting there unused for approx. 5 years. Is that non-use damaging?
I think my mom has a fairly reliable service company, but I would like to know what I would be in for before they come out...just to keep them honest, of course. What can you advise?
Old 05-30-2011, 03:35 PM   #4
JJboy's Avatar
Can you post a bigger image?
Old 05-30-2011, 04:33 PM   #5
Will this work?
Goodman CK36-1T a/c that's missing a piece!!-ac-1.jpg   Goodman CK36-1T a/c that's missing a piece!!-ac-2.jpg
Old 05-30-2011, 05:48 PM   #6
JJboy's Avatar
I hope whoever uninstall the condenser closed the services valves. Leaving the linesets open is not good. Dirt, moisture can damange the compressor and cause corrosion on the coil.
Old 05-30-2011, 06:42 PM   #7
Hvac Pro
yuri's Avatar
Rewards Points: 2,286
Looks like scrap metal to me. It will cost more in $$ to hookup than it is worth. Only to find that the compressor is seized or burnt out. Basic builders grade unit so they were built for a certain price point. The new Goodmans are a lot better as they are 1/2 Amana.
Old 05-30-2011, 10:29 PM   #8
10/4 I agree with Yuri,
don't sink any good money into this junk.
Artco is offline   Reply With Quote
Old 05-31-2011, 09:29 AM   #9
Thanks, do you think I could get more money if I separated out the aluminum and copper or would it be the same to just take the unit in as is?
Old 05-31-2011, 09:51 AM   #10
Take it as it is. (not worth the time to bother ripping apart)
Old 05-31-2011, 09:59 AM   #11
Thanks, I guess I'll use the few dollars as seed money to start my new a/c fund!!!
$1440+ labor only repair on 3 yr. old Goodman unit!?! JMK HVAC 23 05-06-2012 10:45 AM
Lots of cold air coming from missing piece of sill ccathy247 Building & Construction 4 12-18-2010 08:15 AM
Caulk underneath sink drain/plate? doogie88 Plumbing 14 04-16-2009 07:18 AM
Sub is swapping Amana for Goodman Dragon HVAC 22 02-04-2007 07:54 AM
Goodman Air Handler with Missing Parts cougarhsv HVAC 2 01-17-2007 08:14 PM
