Goodman Ck36-18 Question - HVAC - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By bub
Old 08-14-2008, 06:17 PM   #1
bub
Home remodeler
Goodman ck36-18 question
My Goodman ck36-18 compressor stopped cooling(compressor buzzes for a couple of seconds, fan motor never kicks on, only the capacitor hums). If I start the fan by hand then it runs fine but the compressor never kicks on. Any help would be appreciated.
lhoward likes this.
bub is offline   Reply With Quote
Old 08-15-2008, 05:53 AM   #2
oops, did I do that!
Record the information on the capacitor, and try to pick up a new one from a Goodman dealer, if both the compressor and condensor fan use the same capacitor. If they are separate, any local Grainger or HVAC supplier should have them in stock.
Make sure you have the proper voltage at the contactor.
8 Ball is offline   Reply With Quote
Old 08-15-2008, 01:29 PM   #3
bub
Home remodeler
Thanks. The capacitor did the trick. I'm curious though why the contactor continued to hum even when the breaker was pulled and the capacitor was out. Is there power coming from the air handler?
Old 08-15-2008, 06:08 PM   #4
Yup...bub...24 volts!
Good job!!
Evaporator coil for Goodman A/C leschuler HVAC 2 09-25-2008 01:43 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 10:10 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 11:17 PM
Sub is swapping Amana for Goodman Dragon HVAC 22 02-04-2007 08:54 AM
